Ford F-250: How to Replace Upper Hose
Your upper radiator hose is in use from the moment you start up your Ford Super Duty. That's a lot of usage and over time it's going to need replacing. Here's how to do it yourself.
By Makeda - October 15, 2014
This article applies to the Ford F-250 and F-350 (2005-2014).
A Radiator hose pushes antifreeze into the engine to cool the temperature of your Ford Super Duty. Your radiator antifreeze circulates from the bottom of the radiator into the engine. Your upper radiator hose is responsible for taking out the hot antifreeze and running it through the radiator to cool it down. The older the truck gets, the more the hose deteriorates. Always check your upper radiator hose for any cracks, leaks, or unusual color changes.
Material
  • Bucket
  • Screw driver
  • Pliers
  • New upper radiator hose
  • A new bottle of antifreeze
Step 1 - Let the car cool down
Park your truck and let it sit for awhile so it can cool down. Leaving the hood open will help cool the engine down more quickly.
Figure 1. Open the hood and let the truck sit for a while.
Step 2 - Drain radiator
Locate the valve on the bottom of the radiator.
Place a pan underneath it and turn the valve to the left, letting the coolant drain into your pan.
Figure 2. Drain the radiator.
Step 3 - Remove upper hose
Slide the hose clamp 4 inches away from the radiator. You can use pliers to loosen it. Some clamps will have a worm screw, in which case you can loosen it with your screwdriver.
Figure 3. Remove the hose.
Step 4 - Install new upper hose
Attach the new hose and slide the clamp back up to avoid any leakage.
Figure 4. Install the new hose.
Step 5 - Refill antifreeze
Tighten the radiator valve and refill it with antifreeze.
Start your car and let it run for 5 minutes before checking your coolant level. Top it off if you need to.
Figure 5. Refill with antifreeze.
Pro Tip
Remove the battery box on the driver side to give yourself room before you begin.
Related Discussion
