2002 Ford F150 FX4 XLT
Year: 2002
Make: Ford
Model: F-150
Price: $5500
Mileage: 250000
Color: White
Private or Dealer Listing: Private Listing
Location (State): MS
Transmission: Automatic
Drivetrain: 4WD & AWD
Color: White
Engine: 5.4L
250k miles on truck, 115k miles on engine. Comes with some spare tune up parts from when engine was replaced. The engine was installed about 2000 miles ago. At the time, the water pump, belt, spark plugs, exhaust manifold gaskets, intake manifold gaskets, dpfe hoses, fuel pump, fuel filter, and battery were replaced. Battery is 1000 CCA. Cooling system has been back flushed, and thermostat and radiator hoses replaced. Engine is equipped with block heater, but I don’t have the cord to plug it up, but it is dealer available for about $40. All 4 brake rotors, front and rear brake pads, emergency brake shoes, and front left brake caliper were replaced, old brake fluid flushed and replaced with fresh synthetic. Rear differential has recently been serviced and rear pinion seal replaced. Several components of the front end were replaced shortly before I bought it by the previous owner. Front valance was removed due to being broken, but it’s an inexpensive replacement part. Have factory fog lights that were removed when valance was removed. It has cruise control, but the servo tests bad. Used ones are available for around $50 if you need cruise to work.
Note that even though this is an XLT trim truck, the floor mat is factory vinyl and the transfer case is manual shift on the floor. The seats are 60/40 split cloth. All the spare tire equipment is still on the truck with a new spare holder under the bed, and the owner’s manual is still in the glove box. Transmission, transfer case, and both differentials are tight, front end components are tight. Solid, reliable transportation or good weekend wheeler that drives and handles well. Have receipts for all work that has been done. Must see and drive to appreciate. $5500 Firm. Call 601-850-6186.
More pics can be found at: http://s255.photobucket.com/albums/h...20Sale%20Pics/
