1956 Ford F100
1956 Ford F100
Year: 1956
Make: Ford
Model: F-100
Price: $10000
Mileage: 0
Color: Patinized Red & Black
Private or Dealer Listing: Private Listing
Location (State): CA
Transmission: Automatic
Drivetrain: Rear Wheel Drive
Engine: 351C
$10000 or make an offer, I need the cash for another project.
These are the things I have installed and modified:
Rebuilt 351C engine from Clark's Machine in Cupertino, CA
Demon Road Junior 450 4-barrel carb
Aluminum valve covers and air cleaner
Sanderson block hugger headers with 3" collectors
Pertronix electronic distributor and Flamethrower coil (coil is firewall mounted)
Custom 3" dual exhaust with twin Flowmaster Super 40s (people know when you are around)
Aftermarket radiator with electric fan and controller
TCI Streetfighter AOD transmission with Constant Pressure Valve Body and stock torque converter
Ford 9" rear end (needs seals)
3" Drop Front Springs with bushings and pins
Kingpins rebuilt
Classic Performance Products power front disc brake conversion
Classic Performance Products power steering conversion (Toyota power steering box with a Ford pump on the engine)
Re-cored the heater and restored the housing (no more rust)
New stock wire harness set up for GM one-wire alternator (wire harness routed behind the firewall and inner fenders - not hanging from clips in the engine bay)
Rebuilt GM one-wire alternator
VDO gauges mounted in a brushed aluminum panel (speedo, oil pressure, fuel level, water temp, volts)
Lokar Gennie 23" floor shifter and transmission kickdown cable
Black leather shift boot with polished aluminum trim ring
Lokar gas pedal, brake pedal and high beam switch pedal
Flaming River 2" steering column with brushed aluminum 2" drop top bracket
Grant wood steering wheel and mount kit
New grey tweed door cards from an aftermarket interior kit (the complete kit is yet to be installed)
Door latch hardware all new replacements from Sacramento Vintage Ford
Replaced all of the door track felts and internal seals
Reproduction interior door handles and arm rests
Bench seat reupholstered with light grey tweed (bought it from a guy that way and haven't had to install the upholstery I bought)
Front turn signals replaced with Harley style tear drops
New front sheet metal including gravel pan, both front fenders and the right inner fender panel.
Power coated the radiator support, front valance panels on either side of the radiator and the top cross member
Classic Performance Products tilt hood kit
Oak bed wood with stainless mount strips and hardware
Custom one of a kind tailgate latch system that really works!
Available but not installed:
The rest of the interior kit (grey tweed)
Front and rear sway bars for the stock suspension
Windshield, cowl vent and door weather stripping
Honestly the rear cab corners need to be replaced and the driver's side floor could stand it too. The sheetmetal is available and not terribly expensive.
$10000 is the asking price. Make me an offer!
