Keyless Entry Code
Old 08-13-2009, 04:38 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
Keyless Entry Code
When i bought the expedition it didnt come with a manual or the card that has the code on it. Is it somewhere hidden on the vehicle? I know the older models have it uder the dash. Is it the same for 07?
Old 08-13-2009, 09:59 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
Nope not hidden on 07+. Have to go to the dealership.
Old 08-13-2009, 10:10 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
you sure tikt b8?
where is the lock module? they've been putting that code on the module since 2003.
I'm at work now, but I'll try to dig though my Repair Manual when I get home. Send me a PM to remind me though if you can.
Old 08-14-2009, 10:32 AM
berry1234's Avatar
berry1234
berry1234 is offline
TIKT is right, no codes like the old days. The dealer can retrieve it via computer.
Old 09-30-2010, 07:30 AM
vipersinu2's Avatar
vipersinu2
vipersinu2 is offline
2010 expedition 5 digit keyless entry code
2010 expedition 5 digit keyless entry code location. It is located on the (SJB) smart junction box, Passanger side fuse box, remove the plastic panals and look on the rear of the fuse box you will see a sticker with the code. No tools Required!
[IMG][/IMG]
[IMG][/IMG]
Old 09-30-2010, 10:54 AM
berry1234's Avatar
berry1234
Ahhh! Nice. Is the fuse box attached to the body?
Old 09-30-2010, 11:12 AM
vipersinu2's Avatar
vipersinu2
I just removed the passenger plastic rocker panel, then part of the weather stripping, then pull on the passenger side kick panel it will come right off, you will see the SJB and the sticker, I took my pocket knife to start prying the sticker off once started just pull it off there is plenty of room, this project will probably take you all of 15 minutes.
Old 09-30-2010, 11:23 AM
berry1234's Avatar
berry1234
And you have tried the code to make sure it is the door code?
Old 09-30-2010, 12:50 PM
vipersinu2's Avatar
vipersinu2
working perfectly!
Old 09-30-2010, 01:05 PM
berry1234's Avatar
berry1234
Nice find. Great Job.
Old 09-30-2010, 05:08 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
great find. I am going to go find mine just because I know it is there now.
Old 09-30-2010, 10:03 PM
gpfarrell's Avatar
gpfarrell
gpfarrell is offline
I think this qualifies as breaking news! Thanks!
Old 01-04-2011, 08:35 PM
RyanJan's Avatar
RyanJan
RyanJan is offline
Tremendous tip!!! Thanks a million...
I just bought an 08 Expedition as primary vehicle for my wife to drive.
Did not think to check when I bought it, but the keyless entry card was missing and nothing written in the manual.
I tried to call ford to get the code with my vin number and they waned me to go to dealer who wanted to charge me 60 bucks to get the code out of the computer.
I was going to take it to the dealer, but before I got a chance by wife locked the keys in the car. To make matters worse, my son was strapped in the car seat.
The next day, my brother in law found this for me.
Worked like a charm.
Old 03-31-2011, 09:47 AM
SickPup404's Avatar
SickPup404
SickPup404 is offline
I just had to sign up and post a big "Thank you" here!
We bought a 2007 Expedition EL Limited a little over a year ago and it had no "glove box goodies". No manuals, no key code card, and only 2 keys (no fobs).
I've been searching through a lot of wires under the dash with no luck. However, I ran across Viperinu2's post with pics and found our code! The location of the SJB is the same as pictured on ours, however the label was different and the 5-digit code was pretty well smack in the middle with barcodes above and below it.
Old 04-07-2011, 08:57 PM
jdm5630's Avatar
jdm5630
jdm5630 is offline
does this work on a 07?
Quick Reply: Keyless Entry Code
