Will 1997-2003 F150 wheels fit a 1992-1996?
Thanks. IIRC, Dodges and Jeeps have the same 5 X 5.5 bolt pattern as the '92-'96 Fords. However, I understand that the center bore is different. It's frustrating that Ford has decided to change the lug spacing so much over the past 10 years.
I have looked at the adapter plates online. (I was even considering using 6-lug wheels from a '04-'09 since there are so many take offs available from new trucks). But the adapters cost more than the wheels!
Guess I'll have to think about this some more . . .
Dale
Dale
Thanks for the link to the bolt patterns. Tylus, the prices I've seen on-line for adapters run around $129 per wheel. Best price I've seen is $159 per pair IIRC. If you do have a link or two with better prices I will be grateful. I haven't checked every site, but the several I did visit seemed to be pretty consistent price-wise.
Has anyone had experience with adapters? Any strength/breakage issues on pickups?
Dale
Dale
Mike, Wow, that looks really sharp with the Expedition rims. (Obviously the Lightning rims look great, too) Pretty much the look I was wanting to achieve! I just haven't seen many aftermarket rims that I like. I would prefer that my truck ends up looking like it could have been factory. Are those Expedition rims 17"s? Tires are 275s maybe? Did they fit the wheel opening ok? Do they self center on the center hole/hub, or do you need to be exact when modifying the bolt holes to keep the wheel concentric?
Dale
Dale
80-96 F-150 has 5x139.7 lug setup
97-03 F-150 has 5x135 lug setup
FORD WHEEL ADAPTERS
should give them a call. They seem to have a huge selection and most are $44 to 58 per adapter
there are several people running these with the 04+ trucks in the usual area I hang out on FTE and another forum. They haven't had any problems. Add to the fact that trucks like my F-150 is about 6,000 lbs
I'm not a huge fan of them, but they serve a purpose. I think you'd be just fine as long as you aren't doing hardcore offroading, or drag strip applications.
Whatever you choose, get an adapter that has 2 different sets of lugs. Wheel Spacers are dangerous since they stress the lug bolts
FORD WHEEL ADAPTERS
Thanks for the help Tylus.
I've already checked their site. They do have a big selection. Their 4 lug to 4 lug, and 5 lug to 5 lug adapters are in the price range you describe. Their 5 lug to 6 lug adapters run about $100 per corner, but unfortunately they didn't list a 5x5.5 (139.7) to a 6 x 135 option on their site. I thought that was odd, actually.
I will call them directly next week and talk about options.
Dale
Dale
Dale
Dale
here is a picture with the lightning rims and suspension,,,,
