1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2001 F250 4X4 NOT ENGAGING ESOF switch
Old 10-03-2004, 11:58 PM
griffbw's Avatar
griffbw
griffbw is offline
I have a 2001 F250 4x4 and the ESOF switch not engaging hubs, currently I have no 4x4 lights coming on in the cluster when i turn the switch. I am not experiencing any of the vaccum symptoms that most people are suggesting. I When I turn the switch i also do not hear any relays clicking. Relays have been tested, and i waited for the 45 second transfer delay that the manual mentions. ESOF switch has power, and is working properly (I know because I bought a new one in attempt to fix the problem) Basically I have no responses from any of my 4x4 indicators or parts. ANY SUGGESTIONS.
Old 10-04-2004, 02:23 AM
fedextech's Avatar
fedextech
fedextech is offline
have you checked your vacum hoses in the wheeel wells, that run from the frame rail to the spindle. they are bad about splitting and leaking vacum. sometimes the split is hard to see, ussually where the hose goes over the nipple. have a ford day!
Old 10-04-2004, 06:01 PM
griffbw's Avatar
griffbw
griffbw is offline
Looked there but, nothing. Also remember when i turn the switch nothing happens, I cannot even hear a relay kick to turn on a vaccum.
Old 10-04-2004, 06:19 PM
Technitom's Avatar
Technitom
Technitom is offline
ok hopefully this helps.... I'm going by what you've posted so far, and looking in the '99 service manual CD (I figured this may get you close, they didn't change them that much) this is what I came up with..... copied from the manual:
Transfer Case — Electronic Shift on the Fly (ESOF)
PINPOINT TEST E: NO COMMUNICATION WITH THE MODULE — GENERIC ELECTRONIC MODULE
² E1: CHECK FUSE JUNCTION PANEL FUSE 15 (5A)
² E2: CHECK FOR VOLTAGE AT FUSE/JUNCTION PANEL FUSE 15 (5A)
² E3: CHECK FUSE JUNCTION PANEL FOR SHORT TO GROUND
² E4: CHECK CIRCUIT 676 (PK/O) FOR OPEN
² E5: CHECK THE POWER DISTRIBUTION BOX FUSE 22 (50A)
² E6: CHECK CIRCUIT 1052 (T/BK) FOR OPEN
² E7: CHECK CIRCUIT 70 (LB/W) FOR OPEN
² E8: CHECK CIRCUIT 676 (PK/O) FOR SHORT TO POWER
² E9: CHECK CIRCUIT 465 (W/LB)
² E10: CHECK CIRCUIT 465 (W/LB) FOR SHORT TO POWER
² E11: CHECK CIRCUIT 682 (DB) FOR SHORT TO POWER
² E12: CHECK CIRCUIT 682 (DB) FOR SHORT TO POWER (MULTI-FUNCTION SWITCH DISCONNECTED)
² E13: CHECK CIRCUIT 684 (PK/Y) FOR SHORT TO POWER
² E14: CHECK CIRCUIT 684 (PK/Y) FOR SHORT TO POWER (MULTI-FUNCTION SWITCH DISCONNECTED)
² E15: CHECK CIRCUIT 519 (LG/BK) FOR SHORT TO POWER
² E16: CHECK THE HORN RELAY
² E17: CHECK CIRCUIT 810 (R/LG) FOR SHORT TO GROUND
² E18: CHECK CIRCUIT 22 (LB/BK) FOR SHORT TO GROUND
to sum it all up, check your fuses... one in the panel under dash and one in the distribution box (under hood?) if this doesnt get you going in the right direction let me know and I'll try to post and print each page of the trouble shooting chart (each of those E#'s opens another page with a diagram of what to do...monkey proof)
Old 10-06-2004, 09:23 PM
steve95gt's Avatar
steve95gt
steve95gt is offline
I am having the same problem with my 01 F-350. I checked all the fuses.
Any other suggestions out there?
Thanks
Old 02-26-2006, 12:27 PM
ceopi's Avatar
ceopi
ceopi is offline
2003 F350 4x4 ESOF
Did you ever find the problem..I am having the same problem with mine..No noise and no 4x4 light..Thanks
Old 02-26-2006, 02:27 PM
MobeyDick's Avatar
MobeyDick
MobeyDick is offline
Mine don't want to work every now and then. I get out and work the hubs back and forth myself and they work fine after that!!
Old 02-26-2006, 04:43 PM
cookie88's Avatar
cookie88
cookie88 is offline
I'd start by checking/cleaning the connectors on the transfer case. Sounds like a commmunication problem.
Thread moved, member notified.
Old 02-27-2006, 12:20 AM
Musicman250's Avatar
Musicman250
Musicman250 is offline
The 4x4 lights on the dash have NOTHING to do with the vacumn system whatsoever !!! The dash indicator represents the position of the transfer case motor only, the is no indication of operation of the hub vacuum.
Check voltages at the connector of the trannsfer case motor.
If you remove the motor you can also apply 12v to it to the pins to check the movement of the motor.
With the motor off truck, you can crank the transfer case with a socket wrench (3/8 square drive I think) to selection of the 4x4 (2wd-4HI-4LO) and this should light the dash light (with ignition key turned part on).
Be sure to mark the position of the crank nub and the motor spindle BEFORE you play with it so you can put the motor back on afterwards!
On my 2000 F250 I found the motor was powered and turning but the plastic worm gear inside had stripped, so it was making the noise of moving but not actually turning tha transfer case nub.
Read this post https://www.ford-trucks.com/forums/s...d.php?t=438799
Old 02-27-2006, 06:28 AM
ceopi's Avatar
ceopi
ceopi is offline
ESOF Working now
Under the hood I have two small black boxes one has a few relays and 3 fuses and the other had a place for two relays which were not there so I put two relays in and everthing works perfect. now. I just bought the truck so I don't have any ideal who or why anyone would take them out..Thanks for all the help..
Old 02-27-2006, 08:37 AM
chuck641's Avatar
chuck641
chuck641 is offline
like was mentioned above, check the 2 connectors on the transfer case. My brother had the same problem on his '01 and it was those plastic clips coming loose. you can either go buy new connectors or use some zipties or glue to hold them on.
Old 09-18-2007, 03:33 PM
900rr's Avatar
900rr
900rr is offline
i have the sme problems as above nothing is working i checked the fuses i checked the plugs the six prong connector has power while the two prong connector has no power to it in 4wd mode or 2wd mode any help please
Old 09-18-2007, 06:24 PM
redford's Avatar
redford
redford is offline
Received 1,564 Likes on 912 Posts
Do a search on vacumm solenoid. You'll find loads of information.
Old 09-19-2007, 06:20 PM
Beerstalker's Avatar
Beerstalker
Beerstalker is offline
If the light on the dash does not come on it is either an electrical problem or the shift motor on the transfercase is not working. If the light comes on, and the truck isn't in 4x4 then it is a vacuum/hub problem.
Old 09-19-2007, 07:02 PM
Bernie Lomax's Avatar
Bernie Lomax
Bernie Lomax is offline
If anyone needs a shift motor I have one collecting dust that you can have on the cheap. It's a Dorman, installed it and found out my problem was electrical, not the motor.
Quick Reply: 2001 F250 4X4 NOT ENGAGING ESOF switch
