HELP - 390fe Running Horribly
Old Yesterday | 09:06 PM
misrywhippd's Avatar
misrywhippd
6th Gear
Hello all, I have a 1972 F250 highboy with the 390fe. It has always ran great for me, aside from eating a distributor and I’ve taken it on multiple road trips.
I drove it for a good 3 hour drive today, got to my brother’s place and shut it off. I went to leave about an hour later and it was running quite poorly. I took my brothers truck, came back an hour after that and then it wouldn’t hardly even run. After fiddling with the carb, patching vacuum leaks, and adjusting the timing, nothing has helped. I’ll attach a video as to how she sounds, thanks for any help!
File Type: mov
Old Today | 07:10 AM
blue68f100's Avatar
blue68f100
Have you done any work to the engine? I would check the timing chain to see if it jumped a tooth. Without tearing the front of the engine down you would need to pull the valve cover and set cylinder #1 valves to TDC, then see where the timing mark is.
When you adj the timing was the flash consistent indicating it was firing every time?
Old Today | 10:06 AM
misrywhippd
6th Gear
I have not done any major work to the engine, no. When I checked spark in cylinder one it was good, but I do not have a timing light.
When I did adjusted the timing many months ago with my light, I found out the timing mark was already off so I just had to do it by ear.
1401AlecH
Mar 22, 2023 07:33 PM
Horn Hunter
Jul 21, 2022 06:57 PM
Colo79Ford
Aug 9, 2004 12:22 AM
1ole4d
Aug 14, 2003 02:41 PM
64y292
Sep 21, 2002 09:11 PM
