DIY filter rock guard
Old May 22, 2026 | 03:18 PM
speakerfritz's Avatar
speakerfritz
I like to use the long cat ultra high effect filters or some times the long Baldwin filters.
by the time I get to service intervals….i get a few rock chips which sometimes goes to bare metal and once did a pin hole leak.
was walking thru the homedepot hardware department and saw these rubber sewer drain type pipe joints
bought a 3” to try on my cat ultra high effect filters and a 5” to try on the amsoil by pass or cat high efficiency oil filter …just to size them out.
the 3” fits perfect on the fuel filter with some hand lotion as a lube and a few light taps with a rubber mallet.
for the oil filters will try them later today.
my truck has 37@ tires and 4” lift …so even with that + 7” fuel filter tip height increase…still get occasional rock chips.
maybe this will help.
Old May 22, 2026 | 04:34 PM
FishOnOne's Avatar
FishOnOne
That filter is so big it looks like it needs a jock strap... LOL
Old May 22, 2026 | 07:29 PM
Wellibe's Avatar
Wellibe
Active Streak: 30 Days
No way in hell would I run a filter that hangs that low. That's just asking for trouble. I don't even like how low the stock motorcraft filter hangs.
Old Yesterday | 11:22 AM
FishOnOne's Avatar
FishOnOne
Yeah I think I would be relocating that thing or perhaps rotate it 90 degrees.
Old Yesterday | 01:32 PM
speakerfritz
for reference, the center of the axles are about 18" from the ground and the bottom of the filter is pretty close to in line with that.
its probally higher off the ground than a stock oil filter
Old Yesterday | 06:32 PM
Wellibe's Avatar
Wellibe
Are you sure about that? In the photos it appears to be noticeably lower than the radius arms, which would put it below the level of the front axle. I realize photos may look different from reality, but it doesn't look anywhere near 18" from the ground. Just looking at it, it appears to be much lower than my stock motorcraft filter.
Old Yesterday | 06:39 PM
Just Chilling's Avatar
Just Chilling
That’s alright, mall crawlers don’t have to worry about breaking under body parts.🤣🤣🤣🤣
Sorry, I could not resist.
speakerfritz
6.7L Power Stroke Diesel
May 19, 2026 05:25 AM
Hartwig
Apr 26, 2026 08:32 PM
speakerfritz
Feb 12, 2026 08:10 PM
wpg_250
Jun 2, 2024 02:03 PM
z31freakify
17
May 3, 2024 01:12 PM
