Roof trim came loose
Old May 12, 2026 | 06:20 PM
quadna711's Avatar
quadna711
The trim at the back of the cab roof has popped loose on both sides. This is the passenger side and you can see where the clip has split. On the driver side one half of the clip is completely missing. Any tips to secure it back in place or do I have to replace it entirely in order to pop back into place? Bummed the truck only has 13K miles on it when this happens but it does sit out in the sun often.
Old May 12, 2026 | 06:28 PM
Cdepo77's Avatar
Cdepo77
Trailering
This was mentioned in a prior post on here somewhere. I remember reading this same scenario. I forget what was done to remedy what happened. Maybe try searching it on here. Just my .02. Good luck.
Old May 12, 2026 | 06:58 PM
quadna711's Avatar
quadna711
I'll try again. I searched roof trim loose and cab trim loose and didn't find anything.
Old May 12, 2026 | 07:54 PM
cpobst's Avatar
cpobst
The search function is worthless. People used different types of adhesives made for automotive trim and stuff like that.
Old May 12, 2026 | 08:35 PM
CascadeF250's Avatar
CascadeF250
I used black adhesive silicone and so far so good. It’s been 6 months . Others have used adhesives made for installing windshields and some have used trim adhesive. Just make sure to tape the trim down overnight to make the adhesive hold.
Old May 12, 2026 | 09:11 PM
scottz99's Avatar
scottz99
Veteran: Navy
It has been discussed, Look at this
And this
Old May 12, 2026 | 09:12 PM
350Recon's Avatar
350Recon
https://www.ford-trucks.com/forums/1...-broken-3.html
I just google what I am looking for. The forum links are easier to find. I also get more information from the Tremor forum and other forums.
Old May 13, 2026 | 09:19 AM
Rich1961's Avatar
Rich1961
Make sure you clean both surfaces the best you can before applying the adhesive. I used some alcohol wipes and used black rtv with tape holding it down overnight.
Old May 13, 2026 | 11:09 AM
HarveyTruck's Avatar
HarveyTruck
It has happened or will happen to every Super Duty! I’ve even noticed it on the 11-16’s. Ok maybe not every truck but it’s a very common problem. No permanent fix without removing the back glass so a band-aid is about as good as it gets.
It’s happened to me twice on the same truck, both times right side. I used black RTV and it held for several years. Going to have to do it again.
I just noticed it on mine Sunday. Ironically I saw a newer SD parked beside me on Saturday with the same problem. That guy needs some black silicone I said… next day on mine, can’t make this stuff up.
Old Yesterday | 08:15 PM
cpobst's Avatar
cpobst
Just noticed mine was loose today. Gonna try E6000, it's worked great for other things. What a damn stupid design🤦🏼‍♂️
Old Today | 07:15 AM
quadna711's Avatar
quadna711
I cleaned the area, applied a heavy bead of Permatex RTV under the trim, then glued the end down with some Gorilla super glue. Left it taped down tight for about 72 hours before having to remove the tape for a Memorial Day weekend road trip. So far so good. Seems like at the worst case I may have to reapply every few years.
Thanks for the tips.
79calicruiser
Nov 8, 2025 12:36 PM
bwguardian
Aug 6, 2025 08:39 AM
Highboy46
Jul 8, 2024 10:44 AM
NewtoBlue
Mar 3, 2024 11:18 AM
grasfarmr73
16
Mar 26, 2023 10:09 AM
