First oil change - 2014 F250 diesel
Having bought my 2014 F250 diesel last October I finally got to the point where I decided to change my oil at 6,000 miles since the last oil change. I've read about how messy the oil filter change can be and needing a different drain plug like the Fumoto.
Having changed oil in many different types of my own vehicles for the past 35 yrs this was one of easiest as I didn't have to use ramps.
I did buy a new oil drain plug because the existing plug threads were somewhat galled and the plug was a bit hard to remove. Probably was the original drain plug.
I used 13 qts of 5W/40 Shell Rotella T6 and a Motorcraft FL2051S Oil Filter. I did use an open top 5 gallon oil drain pan to catch the oil however what I will do different is empty the oil after the truck oil pan is empty BEFORE changing the oil filter. The oil filter becomes slick with oil and if it had dropped in 3/4 full 5 gallon container the splash would have sent oil out of the pan. I did fill the oil filter before installing but I rarely if ever have done so. I only did it because the oil filter installs in the vertical position.
I don't see the big issue with needing a special drain plug nor puncturing the oil filter before loosening.
To each their own on how one changes their oil. Not everyone had a jacked up 4x4. Nor can we get a 5 gal pail underneath the filter nor the drain plug even on ramps. The EZ Oil Drain Valve I have, very similar to Fumoto, makes it easier for me to use a smaller pail or empty DEF container to drain my oil.
I take a small mop pail and let the oil filter drain into it after i punch a hole. There is one person says they use a shop style vacuum to pull a vacuum on the engine by removing the oil cap and covering it with the vac hose. They say they can change the filter with no leaks or drips.
It is a toss up on whether to pre-fill the filter or not. I don't pre-fill my filter.
But, by all means, use your way if it suits your style and you are happy with your method.
I agree and don't understand the fuss about punching holes and needing valves that restricts the flow. I too fill the oil filter on any engine where that is possible, pumping air thru the lubricating system is best avoided.
I've never heard of any issues with those easy drain oil valves used to replace the oil drain plugs.
I just have this fear that road debris might damage the valve and cause a catastrophic engine failure due to loss of oil.
Even with the easy drain oil valves I would still have to use ramps on my smaller vehicles.
And if you want to have fun change the oil on a Mazda Miata.
I've thought the same in the past but our drain ports/holes are on the side of the pan and on the rear. Highly unlikely that something would affect it but if you had one of those 90 degree elbows on there that maybe hung below the pan, something might catch. And if the truck is used off road often or for rock climbing. You know what they say...opinions, every body got one.
Is that hose clamp sitting in a "grove" and that is what prevents the lever from dumping oil?
The Fumoto uses a blue plastic clip that prevents the lever from movement. If the clip is in place the valve will not drain oil.
I have the Fumoto SX version on my truck and the fitting hangs below the pan. I don't offroad my truck (muddy dirt road requiring 4wd is the worst it sees) and don't have any issues but I would not recommend it for someone that offroads to the point of having debris hit the pan.
My question is, does the clip sit inside a recess? I looks like there is a taper or grove in the drain valve fitting to allow the clip to sit in. Or is the fuel line clamp only steadfast from the spring tension of the camp itself?
For something I might use every 8 months or so I don't see the advantage but it does seem like there is a market. I bet the car mfg's don't provide them from the factory because of potential liability.
I guess I'm a glutton for punishment with 6 cars in my household.
Also, how often do we toss $30 at something for the truck that has no beneficial benefits? Many it is pretty often occurance.
JMHO is all. To each their own devices and whims.
