thoughts on coolant flush
Hello everyone , I am curious about a coolant flush . I Know this subject has been beat to death.
I am a first time diesel owner and I am about to do a coolant flush. the truck is an 2007 f250 6.0 lariat c/c two wheel drive .
I bought the truck about 2 years ago ,to help my son move to hollowman afb. in nm. the truck did great . it has almost 120,000
mi. on it I have and use torque pro app , and my delta is around 11.2 at 70 mph and about 85 outside totally empty . I have been reading
a lot of posts on this . I am going to do a vc-9 flush then remove the thermostat for the rest of the flush procedure , followed by a oil cooler
backflush , heater core backflush , and radiator flush . I would like to know if anyone has done a coolant flush then a oil cooler backflush
before filling the cooling system . if so how successful was it. should I consider replacing the oil cooler thanks in advance .
A water backflush of the oil cooler wouldn't hurt. Be sure to get enough distilled water flushes that you leave MOSTLY distilled water in the engine. The whole system holds about 7 gallons, and at best (w/ block drains open and the lower hose off) you will drain about 3.5 gallons. There is a lot of "hold up" in the system.
After you have thoroughly flushed w/ distilled water, you need to add 3.5 gallons of concentrated coolant (100% coolant) and then top off with distilled water.
Is that close to ambient (91 dgrees)?
What I use isn't readily available (Shell Rotella Ultra). Most people use the Red Rotella ELC. Nitrite-free is getting to be the most common and will work well.
https://rotella.shell.com/en_us/prod...e-coolant.html
If/when I change, I will probably go to a Caterpillar store and get their ELC coolant.
https://puredieselpower.com/products...-52388647.html
I to run G03 and plan to switch to the red. Ordering the back flush kit this weekend. Deltas have never been above maybe 9.
