Fuel injected fuel tank options?
See a lot about the mustang tank being used on relocating the gas tank but cant seem to find anything on what people have used when running a fuel injected motor. Any ideas? Edit. 1950 f1
I am running a 1990 EFI 5.0 L with Mustang tank between rear bed rails. Originally I had the fuel pump located on the passenger frame rail behind the cab, but changed to the same tank, with an tank mounted fuel pump. I chose Tanks Inc sender, pump, vent product, with fuel feed and return lines and mounted a charcoal canister high up in the passenger side front fender area. I changed to the tank mounted fuel pump based on the noise the rail mounted pump would make when the tank was low in fuel; possibly because of pump cavitation. So far I have had to issues.
Filler neck in rear of bed, 20 gal tank.
I used a 1979 Bronco 5.8L V8 tank, at 25.5 gal. between the frame rails behind the rear end on my 1948 F1. The EFI pump system I used was the Aeromotive Phantom in- tank fuel system, this one:
https://www.aeromotiveinc.com/produc...tallation-kit/
You need to pick the system that fits your engine/EFI combination. The Bronco tank was deep enough that I had to also buy the extension for the "sump". Installing the pump and sump can be a little scary as you have to drill a 3.25 in. diameter hole in the top of the tank.
Here is a picture of the Phantom Pump installed in the Bronco tank in the truck.
Philip
Philip
tip49
04-22-2017 08:09 PM
drptop70ss
20
02-23-2014 02:58 PM
