Poor driving conditions
Old 05-19-2019, 10:48 AM
92fseries's Avatar
92fseries
92fseries is offline
I just recently put a engine and transmission in my truck and got it on the road. When driving it pulls away good when you first start driving it, after it warms up a bit it won’t accelerate properly. It bogs out when you give it more gas. Just wondering if anybody had problems like this before. Any input would be greatly appreciated
Old 05-19-2019, 11:01 AM
ZombieF150's Avatar
ZombieF150
ZombieF150 is offline
Check for codes. the computer will store codes even if no check engine light is on. Until then it is a crap shoot as to where to start.
what year truck? what size engine? what transmission? are they the same type engine and transmission that originally came with the truck? is the engine and transmission the same years or within the same swap range as original?
All that information is pertinent.
Old 05-19-2019, 03:36 PM
My4Fordtrucks's Avatar
My4Fordtrucks
My4Fordtrucks is online now
Received 1,360 Likes on 1,074 Posts
I’ll add...What wiring harness did you use?
Old 05-19-2019, 05:41 PM
92fseries's Avatar
92fseries
These are the codes I got. It’s a 1992 F-150 with a 302 from a 1990 Bronco with a E4OD transmission
Old 05-19-2019, 07:16 PM
ZombieF150's Avatar
ZombieF150
Now you have a reference point to start from and correct those issues and see if it changes how it operates.
172 can be caused by a faulty oxygen sensor but also vacuum leaks either in hoses or gaskets can cause it. If you are depending on the nylon hoses, they are probably shot and cracking or broke. Rubber vacuum line can be bought that will slip over the nylon tubes and the vacuum tree. replace one line at a time from beginning to end, that way you don't miss one.. The IAC gasket has a habit of going bad and causing leaks. New one is about 2 bucks and the throttle body intake gasket is about the same ( where your intake hose from the air filter goes). while you have the IAC off, spray it out and clean it with carb cleaner, look at your butterfly plates and see if they are gunked up.
Correct that first then scan again. that may be causing the 332
Old 05-19-2019, 07:32 PM
92fseries's Avatar
92fseries
Yeah I'm going to check all the vacuum lines and gaskets and clean everything up and give that a try before buying a new egr valve
Old 05-19-2019, 09:17 PM
torq'ta 5 8's Avatar
torq'ta 5 8
torq'ta 5 8 is offline
Dan92
02-21-2011 02:53 PM
blrman1962
05-26-2007 07:15 AM
70mach1
02-05-2005 11:10 PM
fishmaker
02-29-2004 08:09 PM
Quick Reply: Poor driving conditions
