Wheel options?
Old 05-18-2019, 06:13 PM
K2thO's Avatar
K2thO
K2thO is offline
Wheel options?
Any advice for wheel options? I'm looking at some American Racing Torq Thrust D - 15x7 or 15x8
Anyone running these? Opinions?
Thanks!!
Old 05-18-2019, 08:01 PM
Christmas's Avatar
Christmas
Christmas is offline
Can't go wrong there.
Old 05-19-2019, 04:26 AM
Crop Duster's Avatar
Crop Duster
Crop Duster is online now
I'm running Rocket Racing 17X8's with 4-1/2 inch backspacing 235/60's front and 255/60's on the rear. I used Rocket's wheels because they have the correct size hub center hole for a Ford truck, unlike a lot of wheels that have a huge center hole so they will fit a bunch of different vehicles. I do believe you could use a 10 inch wide rim with 4 1/2 inch backspacing on the rear if you are careful when choosing the width of the tire. If you go with any large amount of stagger your choices of tires with the same side wall markings and tread pattern get pretty limited.
Old 05-19-2019, 09:33 AM
skidoorulz's Avatar
skidoorulz
skidoorulz is offline
Here is what they look like on mine. 15 6 front 15 8 rear
Old 05-19-2019, 12:14 PM
K2thO's Avatar
K2thO
K2thO is offline
Any pics of your wheels? Which Rocket Racing model are you running?
I looked at their website and didn't see many offered in 5x5.5
Old 05-19-2019, 12:15 PM
K2thO's Avatar
K2thO
K2thO is offline
Those look great. Can't run 15x8 all the way around I'm guessing?
Old 05-19-2019, 12:25 PM
skidoorulz's Avatar
skidoorulz
I think if you went 8 in the front your turning would be hindered. With the 6's I had to thread my steering stops out a little as on a sharp turn the tire woud rub the drag link
Old 05-19-2019, 01:29 PM
Crop Duster
Wheels
Running 8 inch wide rims in the front isn't a problem as long as you don't get too large of a diameter tire. The only place the tire could possibly hit is the radius arm or in my case the sway bar. I could have went with a slightly larger tire in the front but I didn't want them to be out passed the fender lip. The rears would have been a better fit with 3 1/2 inch backspacing but they weren't available in 17 inch wheels.
Old 05-19-2019, 06:02 PM
Amish65F100's Avatar
Amish65F100
Amish65F100 is offline
I run 17x8 Front and 17x9 rear. No rubbing issues at all.
Front: 235/65 R17 (17x8) (0 off set and 4.5" back space)
Rear: 265/65 R17 (17x9) ( -24mm offset and 4" back space)
Old 05-19-2019, 06:18 PM
K2thO's Avatar
K2thO
K2thO is offline
BS and tires?
Old 05-19-2019, 06:28 PM
instig8r63's Avatar
instig8r63
instig8r63 is online now
31-10.50X15s on ten inch wide rims fit nicely under a Uni bed.
Old 05-19-2019, 06:41 PM
Amish65F100
I updated my post with the info. Also I was wrong, I run 17x8 up front and 17x9 in the rear.
Old 05-19-2019, 06:59 PM
wyrm73's Avatar
wyrm73
wyrm73 is offline
American Racing VN309 17 x 8 (zero offset so should be about 4 1/2" backspacing) all four corners with 235/60 R17 Coopers. Obviously, the truck has a ways to go to be road ready to fully test for rubbing issues, but looked OK turning stop to stop.
Old 05-20-2019, 04:18 PM
dubya TF's Avatar
dubya TF
dubya TF is offline
VN 309 15x7 with 245/60s
FordsOnlyGarage
16
09-13-2017 11:27 PM
BAD ROD
03-11-2017 01:47 PM
rfbristow
03-19-2015 12:49 AM
Jeff55F100
11-07-2011 04:56 PM
hav24wheel
Offroad & 4x4
29
05-27-2009 10:01 PM
Quick Reply: Wheel options?
