After market wheels center bore size vs hub size
Hey guys, im looking to replace my stock 16x7 wheels with 17x9 wheels. After doing quite a bit of research, i learned that alot of our trucks are hub centric, and most aftermarket wheels are lug centric, with a bigger center bore than the diameter of the hub. In the end, i decided i want to retain the hub centric setup, as doing otherwise risks shearing off the bolts, and i'll be towing a 36 foot 5th wheel.
Anyway, finding hub centric wheels for my truck is downright impossible. However, i think i found some that will work without hub centric rings, but im not sure. Hoping you guys can help.
The center hub on the truck measures 124.9mm and the wheels i found have a center bore of 125.20mm. Is the difference here negligible enough to mount the wheels or do i need to match the center hub diameter exactly?
Thanks in advance
Thanks in advance
Thanks in advance
Thanks in advance
I think you'll be fine with lug centric wheels as long as you torque the lug nuts properly. I've run a few sets of lug centric wheels (16x8 & 16x10) and haven't had a problem. I don't tow a 36 foot 5th wheel, but I've towed fully loaded peanut trailers which are anywhere from 10-12k pounds, and had no issues. Also, while running the wider wheels, the truck was 100% more stable than it is now with the stock wheels and 305/70/16 tires I'm running...
But yes .3mm is right around .011...or .0055 per side. How close would you like them to fit? Like a close slip fit, or a press fit? What do you suppose the manufacturing tolerance is on the wheel hub?
.011 clearance I'd run them, but that's me.
There has been a couple good threads on this and myself, like you, wanted hub centric which is the reason I chose to go with the 2004 18x9 Lariat wheels. Offset and hub diameter is made for our trucks and they look great with a 275/70/18. They were only offered in the last part of 2004 as Lariat, Harley Davidson and SVT wheels. I got mine on Ebay and I am very happy with them
I did have a slight vibration issue when I had the 16x8 wheels on and was running 315/75/16 mud terrains. But that wasn’t a wheel issue, that was a tire balancing issue...as in I didn’t get the tires balanced. Two months later I was rotating the tires and got my buddy who works at a dealership to balance them. Ever since I got the tires balanced, the ride was smooth as silk...well as smooth as a 3/4 ton leaf spring truck can be lol.
I don't tow much. Heaviest I think I've done is a loaded closed box U-Haul pushing 8K lbs or so. I wouldn't hesitate to tow heavy with the lug-centric wheels though.
My lug-centric wheels were a perfect fit (8x170mm bolt pattern).
Each wheel was good for 3400 lbs load and I kept on par with stock geometry. I got 16x8" rims with a -6mm offset and my OEM wheels were 16x7" with a +6mm. My new rims were 1" wider with the offset moving 12mm (~1/2") keeping things pretty close. It moved the wheel out a tad but that kept me from having any clearance issues with the front springs.
You just need to make sure you get the right lug nuts and the center caps are what you need. The front ones need to be open to operate the hubs if you want and the rear ones need to be long enough to go over the axle housing. Ultra didn't carry the ones I needed but the tire shop had some extras laying around in the back and sold them to me for a few bucks and put them on.
