Factory remote start extended antenna
Doesn't it plug into the VSS module, generally located behind the vent panel pictured below? At least that's where my self installed system is if I recall correctly. You have to peel back the door weatherstrip, again, if I remember correctly. It's been quite some time since I've had it apart. RMST antenna installation starts on Page 11.
https://drive.google.com/file/d/0B7e...dBeWpTVk0/view
Just to verify?
If one of the extended range antennas is purchased all you have to do is to plug it in and run the wire? I have a new truck that arrived yesterday at the dealer. I wanted them to install the extended range antenna and they are telling me that the programming might mess up the electronics. This is a 2019 KR CC 6.2 with adaptive cruise and the advanced towing package. Everything should already be enabled shouldn’t it?
Thanks
Thanks
on
vsccalde
6.7L Power Stroke Diesel
12-12-2018 07:05 PM
