Where is the starter solenoid located on a 1956 f series? I have a ‘56 F350 if it makes any difference. I didn’t take the truck apart, bought it in pieces. Thank you, Dennis
I found the old wiring harness and streached it out. It looks like the solenoid would be above the heater motor. There’s two holes with screws in them. Next question. Where would the horn relay be located? There’s three wires close to starter solenoid in the harness, but I only see one hole for mounting in the firewall. Dennis
Here is a shot of my 54 firewall. My 54 was built late in the year so it is different than your 54. The earlier 54's had a junction block slightly above and to the left of the horn relay.
I had to add extensions to my original style stock 1954 wire harness when I put the new harness in.
So a build date of August 19, 1954 for a 54 model is very late. I do not think my 54 was built in August of 1953 and sat on the lot until December 1954.
