If my EOT is below 75 degrees my truck Will NOT and it will just crank. I have to plug my truck in even if it’s 70 degrees out. Once it gets below 75 EOT **** hits the fan. If it’s below about 140 my EBPV kicks on even if it’s 65 outside and it’s idling. I have a new IPR will that fix the EOT issue?
Maybe the eot sensor is bad. Mine wouldnt start below 50* unless plugged in. Found that my gp's were ALL bad. Now, 6/8 are brand new (2 stuck) and here in the desert with overhead reading ice, she smoked but fired up.
I just replaced my glowplugs glowplug relays starter batteries icp soon ipr. I didn’t know EOT was a thing. But I’ll check into that. Is it hard to replace?
I had answers praying to Alah....lol
Sensor located on backside of hpop, driver side about 3oclock position....sensor atop the hpop is oil pressure.
You physically verify that the gpr is sending a signal to the output lug? Mine was new onky to figure out that the pcm wasnt sending the ground signal thru the orange wire, making me run a designated ground off a switch from within the cab
Pcm ground issue all that stuff on a switch etc etc so it grounds and what not and actually works. Brand new pcm. So glow plugs works. I’ll buy a new sensor and switch it out. Hopefully it works. Best tools and easiest way to do this ?
you can ohm test the sensor ( i you tubed it) but the if the pcm detects a bad sensor it should use a default value to start it. I believe that would give you a code and cel.
I clicked that link and literally everything it said as system is what I have. If the EOT is like 120 it’ll start but it’ll run rough and like crap and it’ll stutter and shake BAD then smooth out at 140 and run fine 180+ runs perfectly
I haven't paid attention to our EOT sensor, but most sensors don't have a normal hex. A normal socket or wrench often works, but if you can't get one to grip well enough, go get a sensor socket. Might be able to borrow one from a parts store if your locals have loaner tools.
I had one like that. Injectors were bad. It had the added glitch that it would smoke at a stop light like a mosquito truck but not smoke going down the highway.
A little update. Finally got around to changing that EOT sensor. And nothing changed besides the fact it’ll start below that EOT but drives really rough until fully warmed up. I have an IPR I could change out was told that could be an issue. But it doesn’t smoke or anything out of the usual.
