Overdrive relay
Overdrive relay
1955 Ford F100 - switching to 12v. Need wiring info/diagram on 12v OD relay. My old one had 6 wires going to it. Picked up a mid 60's Rambler 12v relay (think its #3167318) with 6 posts. However the posts have stampings on them that do not correlate to the Fords. It has two NO, NC, B, 1 & 2. Has fuse on one side stamped NO & B; one end crossed posts 1 & 2; other end crossed posts NC & NO. Can anyone help me getting this wired in as I already have all the other 12v stuff for the conversion. "Petty3377@msn.com" or text 505-635-4291 ... can send pic
So if you have a wiring diagram? That would be appriciated...
Here is a good post/link on the subject from the HAMB: https://www.jalopyjournal.com/forum/.../#post-7985405
Also these are some things I saved for my use when I get to that point in my restoration.
Ross, admittedly I don't have an understanding of electrical theory beyond the basics. It was my understanding that one of the poles of the kick down switch under the gas petal initiates the brief interruption of ignition. Maybe I'm wrong??
The ignition switch can be quickly switched off and on and the result will be the same as hitting the "kickdown" switch. The OD will disengage. Another interesting thing about these units, the governor can be bypassed and replaced with an "on - off" toggle switch which will give you six speeds forward by allowing the OD to be engaged in second and first gear. After fifty plus years I forget exactly what the problem is but the reverse interlock is affected and I believe you must pull the OD cable to get the unit out of OD before the vehicle will go into reverse. Or maybe the vehicle is prevented from going backwards. Use caution.
And of course, we all know the OD gives clutchless shifting once the vehicle is moving. .
IMO, the OD was the greatest feature one could have on these old vehicles.
Put governor in a vise, attach electric drill to shaft. Attach one lead of volt/ohm meter to governor lead and the other lead to the case of governor. Have meter set to test for continuity. As the spinning governor gets up to speed the meter should show full deflection or continuity. At that point the governor is acting as if if has reached it’s about 27 MPH cut in speed.
Hope me this helps,
tom
Hope me this helps,
tom
movieprops
18
12-15-2006 10:02 PM
