Manual Hub Conversion
I believe the 3 bolt locking hubs were on the older generation trucks. You shouldn’t need that.
the warn hubs are nice, but I personally prefer the G2 branch hubs. They’re all steel- no pot metal coated with brass, and they’re a simpler design, internally. They’re also half the price of Warns
My vacuum lines for my hubs are all cracked and (I assume because of that) my auto hubs don't work. It doesn't bother me. I just lock them manually if I need 4wd. Should I unplug my actuator as well and if so, where do I find it? Thanks
I don't know if they are the same or not but going by the pictures the G2 hubs look identical to the Superwinch hubs which I would never recommend. I had Superwinch hubs and they failed in a year, I haven't seen the G2 hubs in person so I can't say much about them. I have never had a problem getting the Warn hubs to fit on a 99-04, in my opinion the Mile Markers are better made than the standard warn hubs and they are quite a bit less.
That's not good, I haven't had that problem with the standard warn hubs, but I am not a big fan of those either because the dial part is plastic, I worked on a truck a couple months ago that had a wheel bearing go bad and the heat melted the Warn hub. I replaced them with a set of Mile Markers and sent him on his way.
dougbrown
11-02-2010 08:38 PM
skonnie-mark
04-27-2005 10:38 PM
Never_a_Chevy
09-29-2004 06:53 PM
