Amsoil BMK21 Oil Bypass Kit installed with pics
Used Woodnthings writeup and decided to mount my Amsoil BMK21 remote bypass oil filter setup. I used a preferred customer discount on the Amsoil BMK21 so it was about $230. I am trying to get the rest of the projects done so I used the kit as a quick parts grab. I knew where I wanted to mount it but didn't want to drill any holes in the frame. Using a joist hanger as inspiration I had a buddy weld me some steel brackets that utilize existing holes in the frame, NO DRILLING! Here is the oil by pass setup, I should have the transmission one mounted this week.
I live in Denver and tow my Rock crawler up the mtn passes so Temps are my concern. I will monitor EGT, trans temp, oil temp, water temp, fuel pressure and boost. Anytjing else I grab with torqunoro app and obdii
pintoplumber
13
06-29-2016 07:30 AM
