Metal plate bolted to cab between bed/cab
I have what appears to be a cast metal plate, thick and oddly shaped, between the bed and the cab, bolted through the cab wall under the back glass. Wondering what it is... seems the nuts are in the gap and headless bolts (does that make them pins?) are behind the bench seatback. There also might be a plate (thinner) inside the cab supporting the 'pin' heads.
Received 3,102 Likes
on
on
i had two identical trucks at the body shop. and i mean identical. both were ordered the same way by the same person on the same day. 89 F250 XLT 351 auto trans reg cab 4X4 even same color, black with blue stripe outside and a blue gray cloth interior..
one came with a D44, one with a D50. both 8800 GVWR. one had a damper, the only other difference was the VIN, one number apart.
roadrash63
09-01-2012 12:40 AM
Hilux
10-17-2009 08:35 PM
