Engine hesitation
I changed the spark plugs dist cap rotar wires and ignition coil it still has a shutter like hesitation as I acceloate I watched some videos and alot of them were saying the same thing the distributer or pick up coil inside the distributer is bad I know it has a miss fire because that what was said in the videos and I know i saw my cylinder 1 spark plug With burn marks around the base but the others were fine
Did you route the plug wires properly? Cross-fire is a very common problem.
courtesy of Steve83
link to your new thread for the same issue: https://www.ford-trucks.com/forums/1...e-shudder.html
courtesy of Steve83
All plugs are in the right fireing order no issue there and I just replaced all plugs dist cap and rotor a week ago because I replaced them in October and last week when I replaced them the cap and rotar was burnt
Fuel filter and o2 sensor I'd look at too for maintenance depending on mileage and when they were last done.
Running a self diagnostic test on your truck is easy to do for codes, no code reader is needed. Google it up, there's lots of videos/threads on it. Report back with any stored codes from a key on engine off(koeo), and a key on engine running(koer) self test and you'll get lots more direction/help. Make sure the truck is warmed up to operating temp before you do it, otherwise that will throw extra codes.
WalterRoad
02-13-2014 01:47 PM
tlizilani
11-13-2010 11:14 PM
