Turbo on 351w question.
How hard would it be to hook a turbo from say a powerstroke onto a 351w, would it be cheap? I mean I'm talking about using a junkyard turbo here so I'm on a pretty tight budget if you didn't reach that conclusion already.
would it be a bolt up ordeal or what?
I'm going with 383 or 393 CI, also would turbo lag be an issue, I saw some guy put a powerstroke turbo on his 351 in his Bronco but he didn't detail the install or any issues he might have run into he did say lag wasn't really noticeable so... I'm also going to be running no more than plus gas premium is too expensive around here! so the PSI is going to be pretty low.
The stock bottom end will make a lot of HP and stay together. Mine is at 700hp now and I'm looking for another 100hp over the winter.
You say "budget", but stroker motors and budget don't really go together. No matter what turbo you use,the hot/cold sides piping will have to be custom fabbed and fuel control will be another big issue. Not to say it isn't doable. I have a single on mine and fuel is controlled by a Holley HP.
You can take a look for more info here: Gen 1 66mm Single Build
As he said, nothing will be cheap except for a jy turbo. If you are willing to invest 100+ of your hours, and have the tools to do it, the rest can be cheap. And then the reality of fuel upgrades (injectors, pumps) and tuning come into play, which will cost quite a bit. There are such things as budget strokers, but ya misewell get forged pistons at the very least.
How hard would it be to hook a turbo from say a powerstroke onto a 351w, would it be cheap? I mean I'm talking about using a junkyard turbo here so I'm on a pretty tight budget if you didn't reach that conclusion already. A 393 build it yourself after machine shop pay and parts is probably going to run you between 2 and 2500 bucks. A short block is between 2500 and 3500 bucks summit or ATK. Not sure what tight budget is. But add a junkyard turbo and rebuild kit for it, and support ( fuel pumps, injectors, and standalone computer that probably wond run an e4od) for 500 conservative low boost hp and you're getting close to 5 grand.
... I'm also going to be running no more than plus gas premium is too expensive around here! so the PSI is going to be pretty low. Not going to have much choice here, going to bet the least compression with a 393 is going to be mid 9s:1 add any boost worth while and you need premium
Is it the right thing to do to your truck probably not, but it is the cheap way to make the power.
91dirtydiesel
02-19-2012 03:05 AM
cjfarm11
45
12-14-2011 02:12 AM
