Press-on pulley
Not sure the dimension, but this is the pulley we use for that pump: https://www.wildhorses4x4.com/produc...eering_Pulleys
We have run across two different size shafts on the Saginaw/Delphi pumps, but sounds like you have the more common one.
Paul
Paul
Borgeson part number for this application, the .750" shaft is 801105
SummitRacing BRG-801105
Borgeson 801105
Borgeson 801105
on
Wildhorses4x4 sells a press on serpentine version, Item #2062
I talked to both Wildhorses about their #2069 v belt and Borgeson about their v belt #801105 today.
Wildhorses4x4 was unable to confirm whether their 2069 is a Saginaw 801105.
I purchased a Borgeson 801105 thru summitracing.
Thanks for posting those links. What I need, however, is the .750 shaft pulley that has the puller attachment not so far out in front of the V belt. I need to go back to the J/Y and get one. Something like one of the photos in this link, maybe not quite to this extent. (The shaft on this is the wrong size.)
https://www.jegs.com/i/JEGS/555/504212/10002/-1
I was thinking of buying this pulley in the link and taking it to a machine shop and asking them to drill it to .747".
TX460Bronco
05-01-2013 10:54 PM
SusanGriggs
06-16-2007 05:13 PM
