2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Hawser fairlead license plate mount
Old 01-19-2019, 06:55 PM
IamLee's Avatar
IamLee
IamLee is offline
anybody have ideas how to mount my license plate to my hawser fairlead? I’ve googled and have seen several options, but I don’t know which one is quality and will work well.
Old 01-19-2019, 10:10 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
I would hang it below the fair lead, centred, on a small loose hinge, so that when driving it blow up underneath, but hangs down stopped. A small stainless steel hinge that’s long enough to attach at both bolt holes of the plate, and affix to the bottom edge of the bumper. Other option is the same hinge, but hinged above the fairlead, so the plate can be flipped back out of the way.
Old 01-19-2019, 10:20 PM
xxxsherpa's Avatar
xxxsherpa
xxxsherpa is offline
I like the idea mhoefer has about the plate hanging down. What about using small link chrome chains instead of a hinge? Maybe too much banging around while moving?
Old 01-19-2019, 10:56 PM
Beast2017's Avatar
Beast2017
Beast2017 is offline
Idk your lights take up a lot of realestate, don’t see where without lowering your light output.. put here’s a few examples of my rig and a buddy’s rig. They old school rigs but ain’t nothing new.
Hello blazer puts his up above the bumper
As do I welded a solid bracket to the top of the bumper right above the warn
Old 01-20-2019, 12:52 AM
IamLee's Avatar
IamLee
IamLee is offline
Those are all good ideas, thank you. I drilled and welded nuts oto the back side of the skid plate on my Jeep, then mounted the plate. That worked well but this skid plate is a little to steep, it would be hard to see. I like the idea of a ss hinge. Any pix of the hinge setup?
Old 01-20-2019, 09:17 AM
Joe T's Avatar
Joe T
Joe T is online now
I think you could conform and bend it under on of the tow hooks.
The other option would be a hinge over the fair lead. Hook the cable under the bumper or tow hook so it will sit flat. May need to shim out the hinge bracket so the plate rests level on the cable.
Old 01-20-2019, 10:07 AM
jriltex's Avatar
jriltex
jriltex is offline
Can the plate not be installed with their bracket?
Old 01-20-2019, 10:56 AM
Joe T's Avatar
Joe T
Joe T is online now
It has a winch there. I’d bolt a stainless ring at the bottom of the bumper on one side and run the cable there then mount as said in instructions but would need a hinge.
Could also shim out and wingnut the bracket they supply.
Old 01-20-2019, 11:04 AM
303 Super Duty's Avatar
303 Super Duty
303 Super Duty is offline
Old 01-20-2019, 07:21 PM
IamLee's Avatar
IamLee
IamLee is offline
Thanks everyone, these ideas are exactly why I posted the question. I’ll let you know what I come up with.
Old 01-20-2019, 09:01 PM
xxxsherpa's Avatar
xxxsherpa
Take the hook off and use the two bolts to attach the plate (or longer ones), re-attach the hook when needed.
Old 01-20-2019, 09:34 PM
HRTKD's Avatar
HRTKD
HRTKD is online now
Boondocker
Received 6,680 Likes on 2,745 Posts
Originally Posted by 303 Super Duty
I made one of these myself. The problem I had was that the backing plate (behind the license plate, not the bracket shown in the link) has to be really thick/strong if you plan to go through a non-brushless car wash. The brushes kept bending my license plate. Eventually is was going to break off. So I sold the truck.
Old 01-20-2019, 10:34 PM
IamLee's Avatar
IamLee
IamLee is offline
that’s funny! Did you replace it with a vehicle that had a license plate that could withstand a car wash?
Old 01-20-2019, 10:39 PM
HRTKD's Avatar
HRTKD
HRTKD is online now
Boondocker
Yeah, I replaced it with an F-350 license plate holder. The rest of the F-350 was a little more money.
On my Nissan Leaf (no winch) the OEM license plate bracket is super cheesy and allowed the license plate to bend in the car wash. I replaced that bracket with one from a Superduty that I found online. Minor modifications to it but otherwise it fit great!
Old 01-21-2019, 07:44 AM
honda250xtitan's Avatar
honda250xtitan
honda250xtitan is offline
lmao that was funny
Quick Reply: Hawser fairlead license plate mount
