7.3l electrical problems
Old 01-19-2019, 01:12 PM
rnhent12's Avatar
rnhent12
rnhent12 is offline
I have a 1999 f-350 dually 7.3l diesel sometimes when it is parked the horn randomly starts blowing radio comes on battery runs down I don't know where to start troubleshooting any suggestions Thanks
Old 01-19-2019, 03:31 PM
DieselDenny's Avatar
DieselDenny
DieselDenny is offline
Eyeball the moisture on the drivers side floor and higher.
Sounds like the welt in your shield is feeding conductive moisture to your electrical privates.
Denny
Old 01-21-2019, 07:28 AM
axmrdr's Avatar
axmrdr
axmrdr is offline
Do you have some type of alarm on it? Could be the place to start.
Old 01-21-2019, 08:45 AM
rnhent12's Avatar
rnhent12
rnhent12 is offline
I have a lund racerback and lighted visor that I am going to remove and sell as I am putting a slide in camper on the truck I see where it is leaking around the windshield that is probably the problem I will have to reseal the windshield can I do this myself?
Old 01-21-2019, 09:13 AM
Walleye Hunter's Avatar
Walleye Hunter
Walleye Hunter is offline
That's a question only you can answer but I can tell you that I wouldn't try it.
Old 01-21-2019, 09:44 AM
rnhent12's Avatar
rnhent12
rnhent12 is offline
I found a glass place that will come out and install a new carlite windshield for $199.00 plus tax I think that is the best way to go Thanks for the advise
Old 01-21-2019, 09:48 AM
DieselDenny
Outstanding idea.
The pros need to do this job. I've seen many try and fail as a DIY project.
Denny
Old 01-21-2019, 11:29 AM
Walleye Hunter
When they do it be there and inspect the situation, it is possible that you have some rust/corrosion around the windshield that should be addressed before reassembly.
Old 01-21-2019, 12:04 PM
rnhent12's Avatar
rnhent12
rnhent12 is offline
I will definitely do that they are coming to my house and I have everything to fix it if needed thanks
Old 01-28-2019, 09:10 PM
kbeefy's Avatar
kbeefy
kbeefy is offline
I would probably suspect a failing body control module.
autoxtech
12-02-2011 07:53 PM
rackhound
Arizona Chapter
16
07-25-2010 01:05 PM
chuy
1999 to 2016 Super Duty
07-13-2006 07:46 PM
jay1971
12-01-2003 08:09 AM
Quick Reply: 7.3l electrical problems
