plan to use aftermarket with toyota type steering box. just don't know if will need duel crank pulleys or water pump pulleys all the kits I have seen don't show pulleys thanks John
I have that from CCP (or was it CPP?)... anyway Saginaw pump i used a double water pump and double crank... one for the alt and the other for the P/S pump.
