Modular V10 (6.8l)
weird idle
Old 01-14-2019, 08:05 PM
speedybill's Avatar
speedybill
speedybill is offline
Trailering
Angry weird idle
99 F350 dually 2wd
V-10, 200,00 miles
Idle goes up & down, sometimes it will stall,
no codes, cannot find any vacuum leaks, going to replace PCV valve,
any ideas?
Old 01-14-2019, 10:54 PM
R&T Babich's Avatar
R&T Babich
R&T Babich is offline
Originally Posted by speedybill
99 F350 dually 2wd V-10, 200,00 miles Idle goes up & down, sometimes it will stall,
no codes, cannot find any vacuum leaks, going to replace PCV valve, any ideas?
Also, check your IAC - Idle Air Control valve.
Old 01-15-2019, 11:06 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Sounds like a stuck IAC - the computer is trying to control the idle and can't.
Old 01-15-2019, 04:42 PM
V10man's Avatar
V10man
V10man is offline
I've had 2 IAC valves go bad, one on a V10 and another on a 4.6L. neither threw a code.
Old 01-17-2019, 04:21 PM
speedybill's Avatar
speedybill
Trailering
Thank The the help.
II picked up an IAC.
Can I take the throttle body off to make it easier to replace it?
Old 01-17-2019, 06:13 PM
R&T Babich's Avatar
R&T Babich
Thank The the help.
You can, but there is a gasket between the throttle body and the intake that might need to be replaced.
The IAC has no input to the PCM so there would be no codes for it.
The throttle body butterfly plate completely closes at idle and the only way the engine gets any air is thru the IAC valve which is controlled by the PCM.
Old 01-18-2019, 08:39 AM
speedybill's Avatar
speedybill
Trailering
Thankx
I'm going after a gasket for the throttle body.
I'll let ya know how that goes.
Old 01-18-2019, 03:44 PM
rock2610d's Avatar
rock2610d
rock2610d is offline
Make sure to note how old IAC is installed. I got a cheap motor once because previous owner installed the IAC upside down.
Motor will not run right if IAC is installed upside down.
Old 01-18-2019, 04:12 PM
R&T Babich's Avatar
R&T Babich
....I'm going after a gasket for the throttle body. ....
While you have the throttle body off inspect the throat below the butterfly for gunk.
Clean with carb cleaner if needed.
I remember a post where idle/running issues were caused by a layer of gunk down there.
Old 01-18-2019, 07:09 PM
speedybill's Avatar
speedybill
Trailering
Thankx.
Itz pretty dirty.
my72ford
02-25-2019 09:27 PM
almonyspm1
09-21-2013 08:27 PM
icrman
06-24-2008 11:48 PM
snsgraham
Modular V10 (6.8l)
07-05-2006 02:41 PM
rshep
1999 to 2016 Super Duty
05-08-2005 11:29 AM
Quick Reply: weird idle
