Saginaw Part Numbers
Does anyone know the part number for the AC/Power Steering Pump Support bracket from a 92-94 Ford Van with a 351W? I’d like to wimp out and purchase the bracket off of ebay if I can as it cold and time is money, and the local pick-n-pull only shows two vans with 4.9s which may or not be correctly listed. It's also a little bit of a drive to Va Beach to go out in the cold to learn they are 4.9s.
This is the ID engineering number marked on the bracket, it is not the part number.
There are no Ford part numbers marked on parts after 1956, just casting or ID engineering numbers, when applicable.
3C511 is a P/S pump support bracket. There's also a 3A732 P/S pump adjusting bracket.
This is what I was looking for. If someone had the part listed, they would include it in the description if they could read it. Also it would help me verify if I find the correct one. I would be eager to pay less than 40 for one shipped to me and less than 60 shipped with a used pump. Else I'll have to hope for good weather to go look. Spring will come after all. Searching 3C511 came up with only F150 brackets.
I never had a part number when I was searching for mine. I just got it from an Econoline van. As long as it is from a mid to late 90's 5.0 / 5.8 it should be fine. I got mine for 40 or 50 bucks with the pump shipped. The old pump lasted about 4-5 years. Had to replace it a few months ago.
deathmobile2
11-17-2012 02:48 AM
fmronquillo
04-23-2012 10:06 AM
84-250
09-25-2008 01:22 PM
