2012 E350 slow gas fill
Old 01-12-2019, 10:38 PM
JCE35077's Avatar
JCE35077
JCE35077 is offline
I知 trying to find the evap canister on 2012 E350 V8 gas. Looked behind gas tank near axle and nothing there. Anyone have any clue where the canister is on this van? I知 hoping that I can clean out the canister or replace it so that I can fill this dang van up with gas without the pump clicking off every couple of seconds.
Old 01-12-2019, 10:43 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
The evap canister is sealed and not serviceable. Your fill and vent hose are your most likely suspects.
Old 01-12-2019, 11:06 PM
JCE35077's Avatar
JCE35077
JCE35077 is offline
I checked those and they池e fine. That痴 why I was thinking canister, but I can稚 find it.
Old 01-12-2019, 11:25 PM
ford390gashog
the canister is on the frame by the fuel filter. The purge valve is closed with the engine off so it's not your issue. You verified the filler neck hose isn't crushed at the frame rail?
Old 01-13-2019, 10:47 AM
JCE35077's Avatar
JCE35077
JCE35077 is offline
Yep, took both hoses off and they池e both fine- no kinks or obstructions. Something is making this tank burp when I try to fill it cause I have to basically trickle the gas in there to get it filled. Takes about 10 mins to fill the tank.
Old 01-14-2019, 04:24 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
Often times this condition is due to the filler neck vent tube being clogged with fuel from past over filling. If you can run some sort of small stiff wire or electrician's fish tape through that tube it might cure your issue.
The filler and vent tubes can both look perfectly okay but sadly that's not always a reliable inspection.
Old 01-14-2019, 06:01 PM
JCE35077's Avatar
JCE35077
JCE35077 is offline
Snaked the lies today - what a pain- but they池e both clear. I did find the canister. Stupid thing is above the gas tank! So can稚 tell what痴 going on there until I drop the tank. Chased the vent line to rear axle and blew air through it- clear. Unrelated but - Never did find the gas filter. Anyone know where that is? I知 gonna fill up tomorrow to see if anything has changed. If not then I guess it痴 gonna mean dropping the tank and ordering a new canister. Anyone know if there is some sort of electrical switch/valve that could be bad and causing no venting?
Old 01-15-2019, 11:00 AM
Gerle's Avatar
Gerle
Gerle is offline
My 2008 has a fuel filter on the left side of the frame, but I saw a post where someone claimed a 2011 only has a screen in the tank, no inline filter.
Old 01-16-2019, 10:48 PM
JCE35077's Avatar
JCE35077
JCE35077 is offline
I think that痴 true, because I chased the fuel line all the way to to engine and didn稚 see any filter. So weird. Filled up today and no dice - still burps and shuts off the pump if I try to pull the trigger more than just a tiny bit. This is so stupid. I知 gonna have to drop the damned gas tank to get to the canister.
barberman91
05-20-2016 01:03 PM
cappo
08-28-2014 06:41 PM
neilc88
02-13-2009 09:15 PM
Boxer19
11-03-2008 05:39 AM
carraizo99
1999 to 2016 Super Duty
03-16-2007 10:06 PM
Quick Reply: 2012 E350 slow gas fill
