EGR/DPF delete kit arrived!
2012 F-350 6.7/133k miles. ( have my second clogged EGR cooler core)
Just ordered a EGR delete kit, DPF delete kit with GDP Tuner and CP4 disaster preventive kit.
I know the lower EGR pipe bolts are notorious for seizing and breaking. I've been soaking them daily with PB Blaster.
Does anyone have any other tips or tricks on these installs before I get started ?
Make sure the truck accepts your tune before you delete.
I didn't have any issues getting my EGR bolts out, but with any stuck bolts, heat is your friend.
The DPF is heavy and awkward so it helps to have a buddy on the other end.
A long pry bar is handy for popping off the rubber isolators on the exhaust hangers.
The hardest part for me that nobody talks about is unclipping the sensor cables from the DPF. Those little boogers are tough to finger.
Monty, I didn't know you deleted. For some reason I thought you were waiting for warranty or something. Very cool. If I ever got one of these, it would be the first thing I would do. Sounds like you have been happy with it.
https://www.ford-trucks.com/forums/s...ostcount=70177
Byron, I deleted back right before the long trip to Myrtle Beach and the Kentucky G2G. I believe it was June 1st. I just couldn't trust it any longer in the shape she was in without throwing some kind of code or derating. So, after talking with Doug, Rodney and Josh, I made the jump and haven't looked back. Not trying to jinx myself, but she's done very well since then. They told me they could get me another one in a trade and my response was something to the effect that you can't fix this one, why would I want you to get me another. I truly have been happy with it. One thing I may should have done was get the muffler. It gets pretty loud up against the interstate jersey barriers...BUT, it doesn't bother me...just the wife and dogs LOL . But yes, I went with the nGauge Patriot with the SOTF ...Love it.
Delete
2014 @ 59998 and got the glorious countdown to 50mph for exhaust fluid fault....Livewire on the way and pipe. Can I run my EGR disconnected for a bit or is that a MUST to delete as well? My pockets aren’t deep
It's recommended to be blocked off, but it's not a necessity. You don't have to delete it, it can stay in place either blocked off or left alone.
It is recommended, but not required as stated above. I bought a plug kit from Shibby Engineering that has every plug needed to cap every plug you take apart under the truck and under the hood. That way, no cleaning the plugs when/if you need to put it back on the truck. Makes it very easy. My EGR is still on the truck, just comolcompl disconnected electrically. No oroblpro. The problem would come as a stuck valve after a while if you reinstall it. HowwHow, the EGR valve is not that expensive and can be changed out easily if need be.
