F-250 5.8L vacuum question
Not sure exactly what you're referring to, but that's a mess. Buy vacuum hose to replace the power booster line to the manifold. You'll need some hardened hose to correct the PCV line, is it even hooked up? That will eliminate the t's that are on there and will ensure their arent any leaks. Then I would replace all the smaller red vacuum lines with silicone. Also, is that the ground cable hooked up to the throttle cable bracket?
e30rik
15
08-27-2016 06:30 PM
78 & 87 Super Cab
11-07-2013 12:44 PM
Eallend7
29
11-17-2012 10:18 PM
LARIAT 85
05-24-2007 07:59 PM
