1963 Temp gauge
1963 Temp gauge
Ok. My new temp gauge is pegged to Hot. I remove wire from sending unit, the needle moves toward Cold But only half way. Running ground to sending unit wire has same result. Not sure if wire to sending unit is supposed to have power to it, but it does not. Anyone have instructions for dummy
Everything you are asking is covered quite well in the shop manual. But I will say if you grounded that gauge and left it that way for any length of time you probably killed it. Any test of those gauges has to be done with the ICVR that you are going to use with the gauge.
I'm not sure if they made a full 1962 or 1963 manual. They might have just been supplements to the 1961 manual. But, the 1961 manual says to test the Temperature Gauge itself in the same way as the Fuel Gauge and that method is to use two 1.5 volt flashlight batteries in series giving a total of 3 volts. Meanwhile the ignition switch is left in the OFF position. Like CD says, if you applied full voltage to the gauge for more than a second or two you have probably already cooked it. I hope not, but if it you disconnect it and it does not drop back down to it's original setting when you bought it then it is likely bad now.
I also always recommend the shop manuals, too. Certain precautions and procedures are covered in there that can keep a person from making fatal mistakes.
Chad
Chad
Chad
Chad
todd jo
07-16-2014 07:44 AM
