Top Loader 4 speed
The input is either spot on or 1" too long. If it's the long input a spacer can be used between the bell and the transmission. But it all needs to be visually checked without the clutch and pressure plate in place (transmission bolted into the bell, bolted to the engine, with the flywheel in place. Input snout must go into the pilot bearing/bushing at least the depth of the bearing/bushing.
Early 3 speeds were great daily drivers but not great racers. Had one behind a mild 312 Y block. Went thru a dozen of them in two years. Wrecking yard was giving me bulk rate on replacements. This was back when they were plentiful and not popular.
Nitpicking alert.
1960s performance toploader 4 speed is stronger than the 3.03 3 speed, stronger than the BWT10 four speed it replaced, and stronger than the BW 3 speeds.
3.03 three speeds are stronger than the BW 3 speeds, but were NOT offered with an overdrive unit.
A "three plus overdrive" is a 3 speed with an od unit, like so:
Ford Borg Warner Overdrive Parts Prices
The transmission in question here is a 4 speed overdrive, patterned on the toploader performance 4 speed, with some parts interchange, but overall weaker than the performance trans due to the issues discussed in the link in post 4.
The 3.03 and the toploader 4 speed look similar but do not share cases or anything else afaik.
The 4 speed OD ratios in 1-2-3 vary depending on car or truck, iron or aluminum, but are not the same exact ratios as the 3 speeds.
Tremec T170 SMOD, SROD, TOD Transmission Specs & Ratios
ClassicBroncos.com Tech Articles » Blog Archive » Toploader 4 speed manual ? Transmission Guide
RUG SR-OD Single Rail 4 Speed Overdrive.
1978/83 F100/150 300/302 / 1978/87 E100/250 300/302/351W // 1977/80 Granada / 1979/83 Mustang/Capri/Fairmont/Zephyr.
The Econoline shift lever mechanism is completely different than F100/150 // The car shift lever mechanism is different than F100/150 & Econoline.
RTS TS-OD Top Shift 4 Speed Overdrive.
1984/87 F150 2WD/4WD & Bronco 300/302.
The shift lever is two pieces and contains multiple parts. It's a notorious POS!
Both of these trannies are "weak sisters." One speed shift, you can kiss the little darlin's good bye.
Replacement parts for these trannies can be very hard to find. Most auto parts store parts clucks have never seen or heard of them.
WOW, I think I will stay away from that trans unit. I have talked to my local machine shop owner, and he brought up the idea of us putting the trans from this dodge truck diesel into my 69 FE 390. We have been friends for about 50 years of course this might try our friend ship a little. He has a dodge truck with a 6 speed trans in it and with his help we are going to attempt to fit that trans from that diesel into my 69 F-100. We know the pilot bearing will need to be reamed out and I am sure we will be modifying the bell housing to fit that FE 390 motor and we will need to check the out put shaft on the trans for the correct length to the pilot and crank. Then the sheet metal work I will have once in the truck since I have the low hump. We will also need to do some drive shaft mods too. We are just in the idea stage and I am not real sure about this swap.
PRUSue
08-31-2016 11:34 PM
craigibc
06-02-2012 02:11 PM
66beater
10-13-2005 11:45 AM
Ford Addict
02-10-2002 08:42 PM
