Torque converter disengaging and seems to get hung in 4wd
So my torque converter is disengaging and then reverse didn't work. I put in 4wd and reverse works. But when I put it back in 2wd it sounds like it's getting hung in between. I put on a vss but the torque converter still disengaged. I bought the vss connector but haven't put it on yet. I checked fuses and besides a couple looking old and dirty, I didn't see any that we're bad or disconnected. I recently had a similar problem and it was a fuse. Could a fuse not be disconnected or broke but still be bad? Any idea would be great since I don't have money to take it to a mechanic. You guys have been great in the past so I have a lot of confidence in this site and all you Saints that have helped me keep Big Blue going. Thank you in advance.
Thank you. I will check that out now.
Is this the "filler plug"? As I was putting on the VSS connector I noticed it was almost falling off. I tightened it down then finished the connector. I then pulled the truck forward about ten feet and noticed I had anti freeze leaking. That's new. Is it related or a separate issue?
Maybe the PO did not tighten the plug correctly. Is that your adapter on there too? Yes, a loose fill plug can cause issues...you could run dangerously low on gear oil. Parts can overheat among other issues.
Coolant loss is not fun. Probably radiator or water pump. Either way, may as well flush it all out and go with some Fleetcharge coolant that has SCAs in it. Consider a filter too.
