Truck Power Washing
Truck Power Washing
I looked at a few threads about washing. About to get a power washer and a foam cannon and was wanting an update on which soap and cannon you guys are using. Also what psi and gpm should I purchase?? I got a 2019 Blue Jeans Platinum and wanna try and keep it clean without swirling it up! Always had white and never cared, but this one is gonna show dirt pretty bad! Thanks!
I’ve evloved over the past few years with washing my trucks as well after seeing what regular “hand” washing can do to a black truck.
So so now I do my own
I have an electric 1800 or 1900 electric pressure washer from Costco. Works great. I have a foam cannon- just get one with good reviews on amazon
use the 2 bucket system both with grit guards for the bottom.
1 bucket is for the soap and mit- the other is to dump your mitt on occasionally to get the dirt off the mitt and re lather in the soap bucket.
I wash my wheels first In A 3rd bucket to keep the brake dust ect from getting on the paint
then i uses a chemical guys XL towel to dry off- however if you have a nice leaf blower that helps keep even more chances of swirl marks appearing.
I have power washed cars/trucks/SUVs but you have to use common sense. You aren't trying to get right up on the paint and blast it. Stand back, at least 2' from nozzle to surface. Most of the washers will have a nozzle tip that turns the stream into more of a "fan" and that's what you want to use. Also not really needed every time you wash your truck - more important is using the two bucket system (one for clean water & suds, one for dirty/rinse), a clean microfiber washing mitt, and a very very clean microfiber drying towel.
For a foam cannon, I generally only use that when I'm doing something like a "degrease" clean (like with Dawn) before proceeding with a hand wash and then paint seal, wax, etc. Otherwise the foam cannon really doesn't "clean" much and you end up having to wash by hand anyway.
I only wash my truck with a power washer, although my truck is ceramic coated. I use a bunch of Chemical Guys products, take a look at their video which gives you a pretty good breakdown on the best way to keep swirls to a minimum.
My pressure washer came from Northern Tool. https://www.northerntool.com/shop/to...7872_200347872
Sorry I can't help much with the foam cannon (I don't use one as I think they are a waste of money), but I use the 2-bucket method with the microfiber wash mitt from Walmart, and a Chemical Guys soap. I don't dry it, as my well water is perfect...leaves no spots or residue. My Blue Jeans truck comes out just as shiny as when it left the dealer!
Received 6,677 Likes
on
I have a foam cannon but I don't use it much anymore. My power washer has a soap tank that uses the same thick soap as the foam cannon. It's way easier to use the power washer than the foam cannon. Either way, I get foamy soap on the vehicle.
But mostly I take my F-350 through the car wash. It does a good job.
I have an electric power washer (sunjoe or something like that) that does a good job overall. However after washing my 2017 F150 Platinum once per week with the power washer and mostly drying by hand and also using the leaf blower, it became a bit time consuming and tiresome so I ended up getting a membership to my local car wash. I ran the F150 through the car wash at least once per week for the past 16 months (so minimum 64 times) and the paint still looks as shinny and new as when I bought it. It’s not a “touchless” car wash, however it’s not the old style plastic bristles that leave swirl marks on the paint. I traded in the F150 about 2-ish weeks ago and got a 2019 F350 Platinum. I have ran the F350 through the car wash 2-3 times so far and it has done a great job every time. I value my truck and I value the paint and if I saw any adverse affects from the car wash I would go back to hand washing but for now, it’s pretty sweet driving home from work Friday evening and filling up with diesel from Costco and then driving through the car wash (located right next to Costco) and then driving home with a nice clean truck full of fuel and ready for the weekend. This is only my experience as I do understand everybody’s experience may be different.
For some caked on dirt a power washer does a little better than a hose. The only real advantage I see from a power washer is you will use less water. Even with a 3500 psi power washer there is still a film of dirt left (maybe if used a different detergent or multiple I would get better results). Plus I think with a power washer you are more likely to get water into area that you don't want to. Two buckets and plenty of rinsing the wash mitt is the most effective. Also regular washing helps so it's not a build up weeks or months of dirt.
If you have hard water, treating it so it's soft will make washing and drying easier.
Takes longer to hook up all of the quick connects from the hose to the Yamaha Power Washer and the CR spotless system get the blower ready to go than it does to apply foam and rinse it of and blow it dry.... I use the big Bigfoot and the smaller Bigfoot by Rupes for my polishing and waxing duties. I even keep all swirls out of my paint on the truck--not covered up with a wax product carnauba or synthetic but driving on the ranch perfect paint is impossible to maintain. For some people like me --- I have to polish out my trucks every 4 months or so, then Pinnacle Black Diamond sealant followed by every month a application of Pinnacle Black Label Synergy Wax.
This is regimen is not for 99% of the folks here but 1% who like the finest finish obtainable then this is just a brief snippet of my products used and process.
