Dakota Digital Install?
Tried test fitting my new VHX Digital gauge system today in my 1950 and I find that the original mounting studs in the dash are to short to install a nut. The studs only come flush with the back side of the mounting holes. For those of you that have installed these, what did you do?
Received 4,132 Likes
on
on
What I have found out is the mounting surface set back on the stock gauges and the Dakota are the same, 1 3/16" to mounting surface. The stock gauge mounting tabs are 1/16" thick and the studs protrude through about 3/16", just enough to get a nut started. The Dakota gauge mounting tabs are just over 1/8" thick, so that extra thickness pretty much takes up the stud protrusion that the stock gauge has. I'm thinking I might just remove the stock studs and install a longer 10/32" screw with a jam nut to hold it in place. What would we do with our extra time if we did not have to modify everything.
Aberasturi_c
03-05-2008 07:35 PM
Hotwheelbill
02-23-2006 05:54 AM
