Drive shafts, double cardan or not?
When I got my 79 F350, the truck was jacked up 6 inches, but the front drive shaft was, I thought OEM stock equipment. I just had another made a couple days ago and now I hear the original front drive shaft was double cardan, is this true? The original owner also had the slip yoke end at the transferase, but I hear its to be at the drive shaft. Who has had their trucks jacked up 6 inches and should this be a double cardan joint and were they that way from the factory?
Any info on this would be great, since I have not put the drive shaft on the truck and can have it sent back to have it modified to a double cardan before doing so.
Thanks!!
Thanks!!
When a double cardan (or more commonly referred to as a constant velocity joint) is used the slip shaft always mounts at the axle end.
my '79 F350 with T-18 4 spd & np205 part time T.C. setting on 6" suspension lift with the double cardan D-shaft.
For what its worth, I've been under many 77-79F250 4x4's & the 79F350 4x4's & I've never seen a truck equipped with the single cardan D-shaft.
If you do go with the double cardan setup, install the double cardan companion flange at the T.C. first, because it will effect the final measurement of the D-shaft length.
reference pic of double cardan D-shaft & mounting hardware.
Thanks Chris, I contacted the drive shaft shop and my New drive shaft can't be modified for a double cardan. So Im going to use it just the way it is for now to see if there is any vibration. Thing is, mine is set up with single cardan in mind, reflecting on your post knowing the flange would also need to be changed. Since mine is a single, your previous post made mention that the double had the slip yoke at the axel, are you saying "to be clear" that the single cardan, yoke end would connect to the transfer case? If I do that, the grease nipple will hit the crossmember. I will need to grease the slip yoke off the truck and then plug it, before install to clear the cross member. The cross member that is in it has been dropped 3/4 of an inch already, but not enough for the grease nipple to clear.
Your thoughts on orientation of a single cardan in my case?
The single cardan D-shaft with only 2 u-joints can be mounted in either position as long as there is enough clearance to do so...suspension travel needs to be accounted for as well, when checking clearances.
I think the idea behind mounting the single cardan slip-yokes at the T.C. was to keep them up in the chassis, away from debris/hazards, possibly extending the life of the parts involved. With a double cardan style D-shaft, this is not possible. The double cardan end needs to be mounted in a fixed position at the T.C. to prevent it from binding, as opposed to the axle end which moves up/down as the suspension cycles.
Honestly, if you have clearance issues like you've described, I don't see the truck being functional for any type of offroad use...if that's your intentions. An example would be...dropping the left front tire into a ditch and the other 3 tires are still on level ground, this would result in contact between the D-shaft & the crossmember as the suspension "droops" down following the contour of the ground.
Driveline angle need to be considered too! A single cardan D-shaft has a certain range of acceptable angular motion & once you get outside of that range you'll experience excessive vibration & increased u-joint wear. The beauty of the double cardan style D-shaft utilizing 3 u-joints, is that it effectively cuts the driveline angle in half allowing a much steeper angle between the axle & T.C. ,eliminating vibration & wear that would be present with the single cardan style. Your driveline shop, if reputable, should be able to explain this much better than I can.
Not knowing how your front suspension is setup, you may need to shim the front axle, rotating the axle pinion angle up towards the T.C. to get to that acceptable range of angular motion. Do keep in mind that shimming the front axle also changes the axles castor angle...if you go too far here you'll start to experience ill-handling characteristics. Castor angle effects the truck's steering ability to return center when coming out of a turn. I use 2° shims on my setup & don't experience any ill effects.
Modifications to the crossmember may be required to get sufficient clearance as well.
There's an awful lot to consider when setting up a functional 4wd system! Hope this was helpful.
With a 6" lift, even a 4" lift you most likely would want a double cardan joint. The double cardan joint will cut your U-joint angle in half and usually since the engine/transmission assembly is sloped rearward, and the distance from the front transfer case output shaft and front axle yoke is so short, the angles are very steep. It might be "ok" if there is no binding and you are using it at very low speeds, but anything more than that definitely want to consider a double cardan joint at the transfer case.
Wiskey88
05-19-2018 06:56 PM
jasond5150
09-17-2006 05:18 PM
