50K + 6.2 report 2013 F350 DRW
We are done traveling for the winter so I looked t the truck stats, we are sitting in South Texas.
Mileage. 53941.8
Towing miles 35138.5
Engine hours 1427
Idle hours. 138
Replaced battery
Changed transmission fluid and filter
Packed front wheel bearings (it's a 2WD)
Replaced brake pads front and rear
Changed oil every 5K
Replaced all 6 tires
Friction modifier for the rear end
Air filter every 10K
This truck gets used hard so I'm happy with what I've spent so far, wasn't to happy with the brakes but I had a lot of trouble with my drum trailer brakes before I went to disk so I'm sure that had a lot to do with it, 16K trailers don't stop all that easy without good trailer brakes.
Denny
Mileage. 53941.8
Engine hours 1427
Idle hours. 138
Replaced battery
Denny
MPG is 8 to 9 pulling. I gross 24.4K and empty the little handle I have on it would be 13 to 14 sometimes lower depending on the area we staying in. I have my oil changed at Ford dealers every 5K and it uses no oil between changes no matter how hard I work it. I just checked it after 3K on my last change and it's still on the fuel mark.
One thing left out I did to my truck was change the shocks last winter to Monroe Gas Magnums after one of my rears started leaking.
Denny
Denny
Denny
