speedo meters for dummies....HELP
12-11-2018, 03:52 PM
on
How can I determine whether my speedometer is bad or if my speed cable is bad ?
12-11-2018, 04:02 PM
Chad
12-11-2018, 04:24 PM
on
Quote:
Originally Posted by
TA455HO
thanks, can you explain the news print ? Please? Which end has the cable head ?
12-11-2018, 11:00 PM
At the speedometer end. To see if the cable is broken disconnect it at the transmission and turn one end and see if the other follows.
12-11-2018, 11:04 PM
If you determine the speedometer is at fault there are vendors advertising in Hemmings Motor News who repair them.
12-11-2018, 11:53 PM
okie trucker
What is the issue, the needle is not moving or is jumping around? Or is the speedo reading too fast or too slow?
12-12-2018, 08:14 AM
NumberDummy
Or 'screaming'?? Proper diagnosis needs symptoms.
Cosmo
12-12-2018, 10:34 AM
on
shadyside1983
thanks shadyside
12-12-2018, 10:38 AM
on
NumberDummy
Needle is not moving. I did install a new speedometer/odometer in the dash. Needle just points straight down.
12-12-2018, 10:40 AM
on
cosmofennema
Cosmo
haha, speedometer isn't screaming, that's me you hear screaming lol
12-12-2018, 10:42 AM
You will need to take the cable core out if you don't have a piece of core/stub to test the speedo with. Insert it into the back of the speedo and spin it with fingers or a drill to test the speedo. Easy problem (hopefully) is that the cable core isn't engaged in the speedo head.
12-12-2018, 10:45 AM
on
resonateur
on my way outside to do that
12-12-2018, 11:47 AM
Inside the speedometer cable housing is a woven steel core. It's supposed to be lubed every so often, but most people are unaware.
When the lube dries out, the steel core binds up inside the housing and snaps.
Auto parts stores sell a 'universal' cable core kit. Cut it to length, coat w/a fine film of graphite, install in the housing.
12-12-2018, 05:32 PM
on
NumberDummy
thank you ND
64fordf100292
09-17-2007 10:40 AM
tcbofade
08-22-2006 03:30 PM
hemiyota
05-05-2006 11:39 PM
RDON
N. California Chapter
03-01-2005 06:41 PM
taylor0987
02-08-2005 05:30 PM
