Vibration/Bumming RPM Related HELP!
Old 12-11-2018, 09:44 AM
StrokerPains's Avatar
StrokerPains
StrokerPains is offline
I have a 1995 Powerstroke Ext Cab 2WD. I drove it an hour today and had smoke coming from under the hood. I opened the hood and it looks like its literally smoking off of the HPOP. Oily residue on Intake boots and other parts. Truck seems to run fine and still making 16 PSI Boost at WOT. Obviously im concerned because a faulty HPOP results in being towed home (yet again). I should also note that the HPOP housing was too hot to touch. Is this normal?
Also have weird vibration/noise that can be heard through all RPM range that changes with the RPM of the engine. Speed does not effect the vibration/noise just RPM.
Replacements and Upgrades made are listed below
HPOP seal kit including non serviceable plug in the summer.
IPR
ICP
Electric Fuel Upgrade (mark fugazotto's)
everything on front of the engine is new (including damper)
injector's rebuilt
new stage 1 E40D 6K ago
EBPV Delete
6637 Intake
Carrier Bearing
CPS Sensor (2 in the glove box lol)
new oil cooler
turbo rebuilt with 360 degree upgrade
trucks odometer when I got it read 380K but I am aware that the PSOM was changed at some point when it went bad according to the owner so I am truly unaware of how many miles the power plant has on it.
Old 12-11-2018, 09:53 AM
Hit Man X's Avatar
Hit Man X
Hit Man X is offline
Received 1,168 Likes on 949 Posts
Thumbs up
What brand damper did you install? I would look there.
Old 12-11-2018, 10:02 AM
StrokerPains
Replaced it with https://www.riffraffdiesel.com/fluid...rmance-damper/ and it did not change one iota and of the sound or vibration. The original Damper looked to be in great shape as well no dry rot or slipping on it. I shouldnt have replaced it but I am done throwing parts at it until I can find a more likely culprit at this point.
I am stumped.
Old 12-11-2018, 10:30 AM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,188 Likes on 816 Posts
Might be TC shudder, check your tranny fluid if good it might be a good time to replace the tc before it damages your new tranny.
Old 12-11-2018, 11:12 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
I am stumped.
Ah, well disregard what I said then. I have the same damper, I love mine. My OEM one was delaminating so I made the plunge!
Are your sensors OEM? I have heard having your PCM flashed to be OBD2 compliant (aka a '96 model or later) makes the truck drive quite a bit better.
Next time I drive my truck, I will check out my HPOP for ya!
Old 12-11-2018, 11:53 AM
oldbird1965's Avatar
oldbird1965
oldbird1965 is offline
That smoke and hot hpop doesn't sound right to me. Maybe clean everything up and check for leaks.
Old 12-11-2018, 02:53 PM
StrokerPains
TC was replaced last weekend to no positive results. Thanks for the response.
I also checked the flex plate for cracks or missing teeth and there is no sign of that either.
Old 12-11-2018, 02:55 PM
StrokerPains
my truck has been flashed OBD2 compliant. Sensors are all OEM except ICP. The ICP according to AE is working as it should.
Thanks I heard from one shop that they can get real hot if they have some sort of internal restriction.
Old 12-11-2018, 02:58 PM
StrokerPains
Thanks ill do that tonight of course. I think it may have actually been steam off of the HPOP turns out when I put the radiator hose back on the outlet to the radiator I may not have had the clamp on quite right which may have sprayed anti freeze out while running when the thermostat opened and ultimately got on the block. Ill know on my drive home I refilled my overflow and got the clamp back on correctly. I am still not sure how hot an HPOP could get or should get.
Old 12-11-2018, 03:34 PM
knottyrope's Avatar
knottyrope
knottyrope is offline
HPOP will be as hot as the engine oil going in to it
Old 12-11-2018, 10:57 PM
oldbird1965
Which is 215° to 220°.
Old 12-12-2018, 12:19 AM
Bob_T's Avatar
Bob_T
Bob_T is offline
A shot in the dark, but power steering pumps make a noise that fits your description when they get low on fluid.
Old 12-12-2018, 06:34 AM
StrokerPains
I changed the power steering pump last weekend to no avail. Turns out some of the vibration was in in fact the drive shaft being out of phase as they say. On my two piece shaft you can have it 180 degrees out of phase. Its enough to cause slight vibration through out the who chassis and cab. So this solved a portion of my vibration which is noticeably less,however, I still have the humming and slight vibration felt in the pedal that appears to be RPM related.
Old 12-13-2018, 01:22 PM
Hussler's Avatar
Hussler
Hussler is offline
Do you have a 3 inch aftermarket down pipe? If it's rubbing on the firewall, fender or passenger side up pipe areas it will cause the humming and vibration in the pedal as you described.
George (GeorgeInSD)
02-07-2017 10:39 AM
shultzaberger
10-17-2014 08:30 AM
Jeff396
53
05-22-2012 06:27 AM
GregN
15
10-31-2007 08:27 AM
01 PSD
20
03-01-2006 06:45 AM
Quick Reply: Vibration/Bumming RPM Related HELP!
