How high do you spin that stock 390?
I am pretty new to the FE motor. I have mine setup as factory with (finally) a good carb tune through a Motorcraft 2100 and good timing through a pertronics ignition. It basically runs out of breath at 4100 or so and truthfully peaks about 3500. It's not a hot rod, never going to be. Just wondering if this is about what you guys are seeing out of good running stock motors?
I have thought about swapping out for a 4 bbl, but realistically I am not going to use the performance (whatever that might be with stock exhaust and driving all four wheels full time) and I love how well it starts, runs and drives with the 2100 at the moment.
And yes, it is a 390 even though its a highboy, the owner swapped the 360 for a 390 from a late 60s Galaxie at some point.
To me, "runs out of breath" doesn't mean the engine won't rev any higher, but power production feels like it fell off a cliff. I am going to assume that's what you meant ,too.
Back in the day, most engines would hit a wall at between 5,000 and 5,500 rpm. On some it was the points were bouncing, on others the hydraulic lifters were pumping up. This was okay, because most engines from the golden years wouldn't stay together over those rpm levels.
Your 390 should fall in this category. If it stops pulling hard at 4100 that's a prime example of too small carb or too small cam. On your engine I'd put a 750 Holley. I'd choose Holley because parts are everywhere and people who know how to tune them are available.
Tired valve springs will do it too, engine will spin no higher than the weakest out of the 16, Crane Cam (I think it was) had an article claiming the OEMs purposefully used somewhat weak valve springs back in the day as a kind of natural rev limiter to help reduce warranty returns from what they called "overenthusiastic motorists". Nobody here would ever have fallen into that category.
Yeah, it seems more air/fuel related than valve floating, plus it runs perfectly fine afterwards and while I suppose it could be lifters or valve springs, the engine rebuild is supposed to be fairly fresh, and looks like it from the condition of the oil valley. Have not had the valve covers off yet though. someone put them on with a ton of RTV!
Thanks for the comments. I'll check the valves and think again about a 4 bbl.
BrotherMabe
03-14-2013 05:02 PM
Hotrodx199
04-13-2011 03:05 PM
slinger34
10-04-2006 02:15 PM
old uhaul
16
06-18-2005 08:30 AM
idealtrucks
06-04-2004 05:32 PM
