Vacuum Advance Stuck
That shouldn't effect starting at all just open throttle driving. Couple months ago I tried to get mine free because truck would knock bad going up hills on the highway. Couldn't get the vac advance free and couldn't get apart it was so rusted so got a reman dizzy from napa and 3 miles after installing the counter weights blew apart and sheared the shaft. Got another only this time new and so far so good. Got a Davis Unified on order just in case though.
I got the vacuum advance to free up with penetrating oil and tapping it gently.
You were right Butcher, it did not effect the cold starting.
I checked the carb and the two squirter nozzles were just dribbling fuel (not squirting).
I cleaned them and had to order new non-stick gaskets. Somehow the one I had stuck.
Anyway, waiting on them and a new steel accelerator pump. I'm pretty confident that was the hard start issue.
Thanks to all of you for your advice.
F-250 WARHORSE
03-24-2017 11:25 AM
The_SnowMan710
08-22-2012 12:28 AM
73F100*8Mile
13
07-13-2007 08:49 PM
