2003 F350 overhead display
12-09-2018, 05:27 PM
my overhead display “works” but it will get dim then slowly get brighter then dim then brighter...
12-09-2018, 06:15 PM
12-09-2018, 06:33 PM
I had the same problem, but after reading here and watching utube, soldered the diodes back in place myself. Takes some patience.... but doable.
12-09-2018, 07:33 PM
two 680 were off and i resoldered them on but now it does the dim thing....
12-09-2018, 09:06 PM
I had 2 off but a thrird one had a broken solder joint, it looked attached until I gently pry’ed it up, Resoldered it and now it works perfect.
Fwiw, solder wick works great for unsoldering and cleaning up boards when doing repairs.
12-10-2018, 08:55 PM
so it works and just goes in and out and i solder it. poorly cause it's in a tight spot. whats more accuarate the miles to empty or the fuel gauge.
12-10-2018, 09:32 PM
My 680's were mia, so i just soldered little jumper wires. Worked perfect and mpg is within .01-.4mpg off then hand calculated
02-16-2019, 07:30 PM
two 680s that were loose or mia can i connect them together since space is limited or does it have to be individual...
02-16-2019, 09:10 PM
so i fixed the little things and it works and its nice and bright the only issue i am having is that the temperature is reading -40...
Pete36
03-12-2017 06:15 PM
Vinford
01-12-2016 03:59 AM
Whitey Ford
10-09-2010 04:43 PM
joejetson
06-15-2004 05:48 PM
