Best headlight housing
Old 12-03-2018, 08:03 PM
Flyboy1100's Avatar
Flyboy1100
Flyboy1100 is offline
I realize most prefer the 05 style for the looks but i find mixed reviews on the light output. is it better or worse than the 03-04 style lights????
I'm getting really sick of the horrible beam pattern produced by my TYC '03 style lights, there are a lot of dead spots in the pattern. tried both regular Sylvania bulbs and Philips Xtra Vision, neither fixes the dead spots which i assume is the reflector. so I am debating buying OEM housings, just not sure which style yet.
a projector retrofit is not really in the budget right now, but as compared to the cost of OEM housings maybe i really should consider that instead.
Old 12-03-2018, 09:27 PM
unleashd's Avatar
unleashd
unleashd is offline
Not sure of 'best', but IMO, the 05-07 style headlights are a great improvement over the prior year headlights. I am currently running the Xtra Vision bulbs on mine and they do a pretty good job. Look around and you can find them on your local CL for under $100 for the pair. These do need you to cut the header panel. If you want to avoid the cutting, then you will need to replace the header panel with an 05+ version.
Old 12-03-2018, 09:40 PM
Flyboy1100's Avatar
Flyboy1100
i can do the cutting of the panel, that isn't the problem. I just don't want to drop the cash if it isn't an upgrade in light quality. The TYC ones are really really horrible however, they look great on the front of the truck, but the light produced is barely better than driving with the lights off
Old 12-03-2018, 09:50 PM
unleashd's Avatar
unleashd
unleashd is offline
If you're fine with the cutting, you will not regret it. Personally, I would save up a bit more and get the projectors retrofitted for even better results.
Old 12-03-2018, 10:16 PM
Flyboy1100's Avatar
Flyboy1100
in the short term I might get the Hella 80/100w bulbs and build a harness. I have had good luck with harnesses on 2 prior vehicles that had crazy voltage drop between the switch and the lights. it could just be the wiring.
now that brings up the question too of how are the lights activated? with high beams on are both filaments active? i would think not so just 1 5pin relay should work fine
i wish i could find a good pic of "this is a pic of the output from my 03 lights, and these are my 05 lights....."
Old 12-03-2018, 10:28 PM
unleashd's Avatar
unleashd
unleashd is offline
See if these help
These are the 05 style lights with the Xtra Vision bulbs
These are the 05 style headlights with the HID retrofit
Old 12-04-2018, 10:27 AM
Greenscobie86's Avatar
Greenscobie86
Greenscobie86 is offline
I've personally had good luck with the 05-07 housings from eBay, I think they were like $95 for the pair with bulbs.
Old 12-04-2018, 11:29 AM
Flyboy1100's Avatar
Flyboy1100
But brand new, OEM or equivalent, direct comparison, which produces the best light output/pattern??
either way im building a wiring harness to get the available voltage into that 13.2-14.4v range and that will help my output, just want the best beam pattern preferably w/o going HID projectors.
Im also tempted to pick up some honda H11 projectors and retrofit those. I would lose high beams if i went that route, but the projectors can be had for about 30/pair. Honestly we hardly even need high beams on our Odyssey because the h11 projectors are so good.
Old 12-04-2018, 12:29 PM
96firephoenix's Avatar
96firephoenix
96firephoenix is offline
Morimoto projectors are pretty well regarded, and have the option of a "Bi-xenon" projector which raises the cutoff shutter for the high-beam.
Amazon Amazon
The amazon link above has good reviews, but most importantly has a diagram of the bi-xenon function (they use the word gobo instead of shutter)
Old 12-04-2018, 12:59 PM
Flyboy1100's Avatar
Flyboy1100
https://www.amazon.com/Nilight-Mini-Bixenon-Projector-Lens/dp/B00B21R0TA/ref=sr_1_3?ie=UTF8&qid=1543947900&sr=8-3&keywords=bi-xenon%2Bprojector&th=1
thanks for that link, will do some more searching. the TYC capa certificed housings were cheap enough off rock auto that I don't feel like i'm wasting a lot of money if i screw them up
for now I ordered a Putco 9007 100w harness, and am getting some used honda relays (per one of the reviews on amazon that said to use the honda relays instead, Mitsuba RC-2201 is the number). I will report back after i get that wired up. the putco harness was cheaper than me sourcing the ceramic plugs etc because theren't arent many options out there for the 9007 socket. for giggles i am also probably going to order the Hella 100/80w bulbs. although the putco harness is only 16ga wiring, so I might be rewiring it or building my own and returning it. but at factory 65w high beams x2 is only 9amp, so 16ga can handle that no problem, so only might be an issue if i were to use the 80/100w bulbs (11a/14a, so approaching limits of 16ga, but it is split between 2 relays)
on thursday i am going to measure the voltage at the sockets and the drop before i install the harness this weekend, or next monday.
Old 12-04-2018, 04:02 PM
96firephoenix
For what it's worth, I wasn't recommending that particular projector, it was just an example, and it had the diagram I wanted. I think that particular one is too cheap to be worth the hassle of trying, then returning because it's cheap in both senses. When a pair is less than half of what a single projector costs, you're in trouble.
My opinion is that rather than up the voltage and get into HID territory, you're far better off going LED at half the wattage. Even compared to stock wattage, you're getting less draw for more light.
Do the research and make sure you get an LED that's designed for the housing you put it in. Don't get a projector LED set in a reflector housing. Seems like you've got a good handle on what you're doing though.
Old 12-04-2018, 05:47 PM
Flyboy1100's Avatar
Flyboy1100
im not trying to get to HID voltage, just closer to the max/best voltage for the bulb. Lumens are rated at 12.8 and life at 14.0. Going above 14.0 and you start sacrificing life a bit, but mid 14s is safe enough based upon my last 3 vehicles i have built harnesses for, i forgot about my subaru foglights, so my Buick had a headlight relay harness on it for over 10 years and my pickup for 2.5 and my subaru for about 5.5yrs now.
I think most manufacturers got away from running the current through the switch now because it was a stupid idea that was used for way too long.
Tons of great info at danielsternlighting.com
I will see how the harmess helps or hurts( the beam pattern is not great on the TYC) i just cant tell if it is the reflector or most likely a lack of voltage. Then from there i can try to figure out if i should get OEM 03-04 or 05-07 housings or retrofit my TYCs.
I still would really like to know what has better output, the 03-04 or 05-07.......but no matter how much i search I can’t seem to find that info
Old 12-04-2018, 06:47 PM
seijirou's Avatar
seijirou
seijirou is offline
I have a set of the 05 style with the morimoto projectors in them, put together by a member here. I've had them for a couple years now and I'm very happy with them. They have the "high beam" shutter.
Sorry I've never done a halogen comparison between the 04 and 05 headlight styles.
Old 12-04-2018, 09:03 PM
Flyboy1100's Avatar
Flyboy1100
Those do look fantastic, but if i were to do hid projectors i would just use my 03 style lights since i think the bucket area is larger
Old 12-05-2018, 12:05 PM
RPhil's Avatar
RPhil
RPhil is offline
---pictures cut---
How did you go about finding a member on there to have this work completed? I would eventually like to upgrade and a plug-and-play solution from someone on these boards seems like a decent avenue to pursue.
Quick Reply: Best headlight housing
