Lower control arm 97 f150
are you sure you need the entire arm unit, or just the ball joint ?
I have seen several discussions where the guys could not get the torsion bar out of the a-arm and had to remove and take to the shop for extensive work... the two bolts holding the a-arm bushings to the frame are not a big deal. probably 21-22 mm heads.
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
06-09-2007 05:23 PM
