I'm hammering a 2x4 wedged between my starter and oil pan. Help
Okay have a 84 ford f150 with a 351 . 4 wheel drive. Sometimes I go to start it up and it starts fine, and fast. Then sometimes I get in and try to start it up and there is this God awful screeching noise and nothing. Along the line of trying to figure this out, I ended up having a 2 foot long 4x4 wedged up in between my starter and the oil pan. . And for some reason whatever space its causing or holding whatever in place, it will start up again just fine. Every drive or two, this happens and I have to get out and get under the truck with a hammer and smack this 4x4 upward a few times and then it'll start again.. this sounds crazy to me...but can anyone tell me what this is about or how to fix it
Should be easy enough to verify. Sounds like the problem is easily duplicated in your driveway. Next time the starter acts up on you, leave everything as is. Don’t try to start it. Leave it in the same condition as when grinding.
Remove the starter and inspect the teeth on the ring gear. If chewed up, you’re looking at a new ring gear. If okay, then it’s your lucky day and you only need a new starter.
grayson20
09-23-2016 10:22 AM
Flaflathead
09-10-2005 01:33 PM
waltp
10-08-2004 10:07 PM
