Block Heater
Old 11-18-2018, 06:50 PM
Leto236's Avatar
Leto236
Leto236 is offline
4wd Low
Block Heater
Hey guys!!
I had a wake up call last winter when I went out to my truck and unplugged the block heater cord. It separated with little strings of melted plastic sticking to each end... So now that's cold i'm finally figuring it out.
I bought a new heater cord and I went to check the ohms tonight. It is showing 28.5. Way over the 15 ohms that i have seen in posts here. Does that mean my element is bad?? It's about time for a fluid change so i thought i better see what you guys think before i put myself through that.
Thanks for looking!!
AJ
Old 11-18-2018, 06:56 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Generally if the cord melts, and it wasn't pinched or cut to ground or something, the heater is bad. I'd see if you can look up Fords spec's on it first and go from there. Maybe someone will check in with them.
Old 11-18-2018, 08:27 PM
Colorado350's Avatar
Colorado350
Colorado350 is offline
AJ, if you’re due for a flush anyway I’d change it out because depending on what year (?) truck you have it’s 15 years old. And it’s easier to change when the block is empty. And if you live in a climate that justifies plugging it in why not just know it’s not going to stop working when you need it most?
I bought this one for mine because it’s made in the USA ���� and it’s not some cheap Chinese special. https://www.ebay.com/itm/1500W-Ford-...-/110753623800.
Old 11-19-2018, 10:14 PM
Superdave71's Avatar
Superdave71
Superdave71 is offline
ten characters
Old 11-20-2018, 09:56 AM
dmd's Avatar
dmd
dmd is offline
On a side note, what are you changing the coolant to? You can get away from additives if you use the CAT EC-1 red coolant. There is a cutoff though if you have a early 99 or before
as a general line. Something to do with injector cup sealant.
rocket_scientist
2017+ Super Duty
18
12-30-2017 04:25 PM
dyoungen
11-18-2014 10:46 AM
WALJON
19
12-12-2009 09:10 PM
immastrokinnow
02-23-2008 10:43 PM
'06 Dually Boy
03-01-2006 01:00 PM
Quick Reply: Block Heater
