I would like to turn on the puddle lights while plowing. I did the bypass for the spot lights on the back of the mirror but want to use the bottom puddle lights while driving also I just plan to use them on some of the dead ends streets I plow. Thanks
I plow too and that would be a nice mod. Help us out comuputer guys
What's this bypass for the spot lights? I haven't heard anything about it. I have the spot lights & it would be nice to be able to turn them on without being almost completely stopped.
Mirror spot lights on at any speed
In the green connector cut the grey wire in Pin #2 and connect it to Pin 1 that is hot all the time. +12V on Pin #2 allows the mirror spot lights to be turned on. The module is located on a metal plate right by the accelerator pedal under the dash.
